Vista - DVDRW wont read disc after failed burn
Old 02-19-2007   #1 (permalink)
requin
Hello,
I was burning a DVD+RW using Roxio that came with my HP. For some reason,
the burn process failed or timed out. I hit the Cancel option in Roxio but
it took foreever to stop (more than 10 mins) so I forced Vista to reboot.
After reboot, I could not eject the disc in the drive and the DVD Drive did
not appear in Device Manager, only my secondary DVD Drive was there.
I uninstalled it via Device Manager and rebooted.
At reboot, Vista recognized both drive and installed them.
Device Manager show the 2 drives working properly.
However, since then, my DVD Burner (HL-DT-ST DVDRRW GSA-H30L) does not read
any kind of disc (DVD, CDs...) and I do not hear it "spool" up when I put a
disc in.
I have tried the following:
-Uninstall the drive via Device Manager>scan for hardware: Vista recognizes
the drive and installs it properly but problem persists.
-Performed a system restore to a known good configuration. Didn't work,
problem persists.
-Uninstalled Roxio: didnt work, problem persists
-Re installed the LightScribe drive, same result
The drive appears in BIOS and in Device Manager.
I read somewhere here about modifying and deleting some settings in the
registry but I have never touched or modified the registry before so I am not
comforable doing that (btw I dont have a lower filter, just an upper one,
whatever that means).
I am short of having to restore my computer to factory settings, which would
be a huge annoyance.
Does anyone have a clue that could help me?
Many thanks,
Old 02-19-2007   #2 (permalink)
David B.
Re: DVDRW wont read disc after failed burn
If the drive doesn't spin up it is likely bad, contact HP tech support for a
replacement.
Crosspost, do not multipost http://www.blakjak.demon.co.uk/mul_crss.htm
How to ask a question http://support.microsoft.com/kb/555375
How to Post http://www.dts-l.org/goodpost.htm
http://www.db-pc.com
"requin" <requin@discussions.microsoft.com> wrote in message
news:33739C4C-587E-4FA8-A10C-1A861824FC2A@microsoft.com...
> Hello,
> but
> did
> read
> a
> disc in.
> recognizes
> problem persists.
> not
> would
> Many thanks,
Old 02-20-2007   #3 (permalink)
VSO
RE: DVDRW wont read disc after failed burn
You're not alone, my gatewat GM5407E is having the same problem, so its I'm
sure its a MS Vista problem. Gateways tech is in the dark also. All they know
is use system restore. Spent 3 hrs on a longdistance charge phone call with
them. They said to take it to a repair station like bestbuy and have then try
to fix the problem!!! think we will have to wait untill MS comes up with the
fix.
<<VSO>>
"requin" wrote:
> Hello,
> disc in.
> problem persists.
> Many thanks,
Media center wont burn recorded tv to video disc Media Center
Solved DVD RW goes to burn folder when trying to read any disc General Discussion
Problem: Icon on desktop when CD or DVDRW has disc inserted Vista hardware & devices
Can't view data disc content - tries to burn a new disc Vista hardware & devices
Vistas DVD burning software, made disc but wont read on XP Vista General
