Vista - CD-ROM-unit, corrupt config info in register (code 19)
Old 02-21-2007   #1 (permalink)
WhiplashInfo.se
Hi, I just upgraded from XP to Vista Enterprice and has faced a lot of
problems.
One of them is that the Vista does find the CD-ROM unit, but rapport a error
message:
A driver was found but a error occurred when the driver should install.
The config info in the regsiter is either incompled or corrupt. (Code 19)"
I then run and bought a brand new CD-ROM, installed the hardware and started
Vista - but with the same result, except that Vista new a hade installed a
new CD-ROM, but still report the same error. Confusing....
Another big problem is my Creative Audigy 2 ZS Platinum Pro. Here Vista act
nearly the same as with CD-ROM unit.
What to do...?
Tomas
WhiplashInfo.se helps injured and server ill persons (non profit).
Old 02-22-2007   #2 (permalink)
Rick Rogers
Re: CD-ROM-unit, corrupt config info in register (code 19)
Follow the steps in method 1 of this article:
http://support.microsoft.com/kb/320553
Then reboot and let it reinstall.
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"WhiplashInfo.se" <WhiplashInfose@discussions.microsoft.com> wrote in
message news:63C643FE-41BC-4F3A-BCC5-610D07628C13@microsoft.com...
> problems.
> error
> message:
> started
> act
> What to do...?
> Tomas
Old 02-22-2007   #3 (permalink)
WhiplashInfo.se
OK - I followed the advice, even though it was stated at XP, but it worked
fine. The problem solved.
Thanks!
Tomas
"Rick Rogers" wrote:
> Hi,
> Best of Luck,
> > problems.
> > error
> > message:
> > started
> > act
> > What to do...?
> > Tomas
Unable to register this virtual machine config file Virtual PC
Extending app.config with addtional config .NET General
app.exe.config on XP but app.config on Vista x64? Vista General
registry info corrupt/missing Vista General
