Vista - Converting my external USB FAT external hard drive to NFTS
Old 02-21-2007   #1 (permalink)
ladymsvee
Hi:
I just purchased a maxtor usb external hard drive, while the computer has
recognized it, I cannot format it or convert it.
When I try to convert it using the command prompt saying it cannot
determine file system.
When I try to format it does read it all.
I am operating windows business vista, as this was purchased from e-bay the
item was probably run under a earlier version of windows can that be the
problem?, if so then I need to use the compatiablity wizard to operate it
under an earlier version but how do I apply the wizard to hardware when I
thought it can only be used for software?
It is a FAT system and not a FAT32 system- should I convert to a Fat32
system first and then NFTS? Or are they the same? I'm going to Maxtor to see
if their are any solutions there,
Thanks for the help.
Old 02-22-2007   #2 (permalink)
Helping out
RE: Converting my external USB FAT external hard drive to NFTS
you should have no problem going from fat to NTFS but i have never tried it
before, but i would not think there should be a proglem. as for the rest read
my post at the link below for where to go to format and partition things if
you like. i was able to format my 160gb usb drive using that. just right
click on the drive and format.
"ladymsvee" wrote:
> Hi:
Old 02-22-2007   #3 (permalink)
Helping out
heh i for got to post the link
http://windowshelp.microsoft.com/com...g=en&cr=US&p=1
"ladymsvee" wrote:
> Hi:
external hard drive Vista hardware & devices
RE: Need to convert from Fat32 to NFTS on external HD Vista hardware & devices
Re: Need to convert from Fat32 to NFTS on external HD Vista hardware & devices
External Hard Drive Use? Vista hardware & devices
External Hard Drive Vista General
