Vista Tutorial - Vista - Bluetooth USB adapter - No icon in Control Panel to setup device
Old 02-22-2007   #1 (permalink)
*Darren*
Guest
Hi
I have installed the drivers for my BlueTooth dongle in vista and the device
is fine in device manager.
However, how do I use the thing?
XP used to have an icon Bluetooth places on desktop or something.
I read online that vista should have an icon in the control panel but i
cannot see any utility to use my bluetooth device.
I have checked in sounds+devices as advised online and also classic view of
control panel.
thanks
Darren
Old 02-23-2007   #2 (permalink)
Andy Snook
Guest
Re: Vista - Bluetooth USB adapter - No icon in Control Panel to setup device
Have you tried entering "bthprops.cpl" in the run box? (without ")
Thats another way to get into the bluetooth control panel.
"*Darren*" <nobody@home.com> wrote in message
news:45dd85d7$0$136$7b0f0fd3@reader.news.newnet.co.uk...
> Hi
> device is fine in device manager.
> of control panel.
> thanks
> Darren
Old 03-06-2007   #3 (permalink)
Diamontina Cocktail
Guest
> Hi
> of control panel.
Unfortunately you may be having the same problem I have. I have a Dlink
DBT-122 and it is seen in System Properties but not under the Bluetooth icon
under control panel. Vista doesn't work with a lot of Bluetooth dongles.
One thing you can do though is to download the Windows Mobile Device Centre
from Microsoft but make sure Activesync is NOT installed before you install
the device centre.
Removing Bluetooth Devices Icon from Control Panel - Windows Vista Business Vista performance & maintenance
Bluetooth Device Control Panel Share Tab? Vista General
Bluetooth Device Control Panel Share Tab Vista networking & sharing
Bluetooth Device Mngr Missing from Vista Ult Control Panel/Hardwar Vista hardware & devices
Bluetooth Device manager in control panel not working? Vista General
