With via AC97 sound- soloution - no volume control at Operating System level...?
  1. #1
    Ron Bartle Guest
    Are there other folks haveing the problem that (even with trying a couple of
    different drivers - i.e. from Realtech and MS-) the AC97 Onboard Soundsystem
    only allows volume control at the application level. Any form of conrtolling
    the volume settings at o.system level does not work.
    This also means that for instance using a Multimedia Keyboard to try and
    controll volume also does not work.
    Any ideas for a solution to this?
    ron b.
  2. #2
    MFS Computers Guest
    RE: With via AC97 sound- soloution - no volume control at Operating Sy
    http://www.realtek.com.tw/downloads/...&GetDown=false
    second one from the bottom worked well for me using the os volume now.
    > ron b.
  3. #3
    Ron Bartle Guest
    Re: With via AC97 sound- soloution - no volume control at Operating Sy
    Hi - Thanks for the tip but I had tried this one yesterday with no change in
    the results.
    Perhaps the fact that what I have is an on-motherboard sound device makes a
    difference?
    M-board is the PC-Chips K8/M860 with Via K8T800 Chipset Family/8237
    I tried a via driver that was listed as compatable with the 8237A which is
    apparently a HDef version of the 8237? This gave a fault report during
    installation that it had not found a Hi Definition device and did not work.
    A 64bit visa compat. device for the 8237 has illuded me so far.
    Gratefull for any further tips or assistance that folks might be able to
    offer.
    Thanks again for the try - like my dear wife says, "Computers are only
    human!" <- or at least as different as one human from another often
    apparently!>
    ron b.
    "MFS Computers" <MFSComputers@discussions.microsoft.com> schrieb im
    Newsbeitrag news:ADE2BD19-D86F-42BA-999A-DCDB75761A41@microsoft.com...
    >> of
    >> Soundsystem
    >> conrtolling
    >> ron b.
  4. #4
    MFS Computers Guest
    Yup it's just one of those things, hopefully the VIA driver could have
    knocked it out for you, but different manufacturers have different
    implementations for the intergrated chipset.
    My Model is an ASUS A87-E and worked the 1st time, but now I'm running into
    mouse drivers that are not working quite yet.
    Welcome to the MS Test Bed AKA consumers base.
    > the results.
    > difference?
    > offer.
    > apparently!>
    > ron b.
    > >> of
    > >> Soundsystem
    > >> conrtolling
    > >> ron b.
With via AC97 sound- soloution - no volume control at Operating System level...? problems?
Shortcut to Volume Control other than in system tray? gpzbc Vista General 5 23 Aug 2007
System volume control doesn't work wglmb Vista General 5 22 Apr 2007
System Volume Information out of control! Mike Vista file management 13 13 Jan 2007
Volume control on the system tray does a disappearing act =?Utf-8?B?QmFoYWRpcg==?= Vista General 0 17 Sep 2006
Thank God that I have a MSDN Operating Systems Level Subscription! Kevin John Panzke Vista General 8 12 Jul 2006
