Vista - Vista does not recognize dvd burner in DVD maker or media center?
Old 02-24-2007   #1 (permalink)
avdog
I have an asus DRW 1612BL Drive: I see other people are having the same
problem but cannot find a answer anyware?
Old 02-24-2007   #2 (permalink)
Jupiter Jones [MVP]
Re: Vista does not recognize dvd burner in DVD maker or media center?
Double check and reseat all connections.
Verify the jumper settings are correct on all devices on the same channel as
DVD drive.
What does ASUS say about Vista compatibility?
Jupiter Jones [MVP]
http://www3.telus.net/dandemar
http://www.dts-l.org
"avdog" <avdog@discussions.microsoft.com> wrote in message
news:E1EF28E3-3567-4BF2-870F-3BE74815AF26@microsoft.com...
Old 02-24-2007   #3 (permalink)
avdog
RE: Vista does not recognize dvd burner in DVD maker or media center?
Old 02-24-2007   #4 (permalink)
avdog
The burner works with other software just not vista programs?
> DVD drive.
> Jupiter Jones [MVP]
Old 02-26-2007   #5 (permalink)
Clark
What does device manager show for the drive. I had 2 drives that
disappeared one day. The device manager showed a yellow (gold) circle next
to them. They worked fine in XP, so it had to be something with the Vista
install. It turned out the Upper Filter Lower Filter fix solved the problem
and the drives were visible again. Some other piece of software must have
put those entries in the registry.
http://support.microsoft.com/kb/314060/en-us
Clark
Old 02-26-2007   #6 (permalink)
avdog
everything is fine in the device manager no errors. Drives work with Nero
and other programs just Vista does not work???????????????
> Clark
Old 02-27-2007   #7 (permalink)
John Pasley
I'm having the same issue will all 3 of my burners. 2 are Plextors and 1 is
an NEC/Sony. Ashampoo works as advertised but burning within Vista does not.
I'm always told my blank media needs formatting but can't be formatted.
news:6DBCCCB0-25AB-494E-8144-5E5715FDD9D6@microsoft.com...
>> next
>> Vista
>> problem
>> have
>> Clark
Old 04-01-2007   #8 (permalink)
Lomax
The problem is with the driver for the JMicro IDE controller.
Out of the box, Vista uses a standard microsoft driver for the JM36x
IDE controller and all works fine. A few weeks ago, JMicro released a
driver that came through auto updates - this driver is screwy and
causes your dvd burner to no longer be seen as a burner by windows.
Go to Device Manager, and look at the properties for your JM36x IDE
controller. You need to roll this back to the generic microsoft one.
You should be able to click "Rollback Driver" on the properties screen.
Lomax
Lomax's Profile: http://forums.techarena.in/member.php?userid=24128
View this thread: http://forums.techarena.in/showthread.php?t=691181
Windows DVD Maker will not recognize my DVD burner Vista music pictures video
Vista Media center does not recognize my Asus 7134TV tuner card Vista hardware & devices
Vista Media center does not recognize TV card....... Vista hardware & devices
Windows DVD Maker doesn't recognize my DVD Burner Vista music pictures video
Re: My LG GSA-H21L DVD/CD burner doesn't recognize blank media Vista hardware & devices
