| | Problems with screen resolution after login Hi, I installed Vista Beta 2 yesterday but keep having problems with the screen resolution on startup. The settings i have when i shut down Vista doesn't seem to stick. When im at the loginprompt I have a screen resolution of 1280*720 (which is what i want) but after a sucessfull login the resolution changes to 1280*1024 with a refresh rate of 85 hz. That would have been nice, as long as both my displays could handle that resolution. My computer is an HTPC connected to a 26" LCD-TV (native resolution of 1280*768) and a front projector (native resolution of 1280*720) and the problem is that my LCD-TV cand handle the increased resolution after login. Ive tried to install the ATI-drivers with the Catalyst control center but that hasn't solved the login/startup problem. Has anyone seen these problems previosly? Is there a magic setting to find somewhere deep down in Vista that could solve this problem? Best regards /Martin Roth |
| Resolution changing at login screen after boot | Graphic cards | |||
| Problems with screen resolution | Vista hardware & devices | |||
| Screen Resolution Problems | Vista hardware & devices | |||
| Problems with screen resolution after login | Vista hardware & devices | |||
| Wrong screen resolution after login | Vista hardware & devices | |||
