Vista - Wireless Natural Multimedia Keyboard, No volume control?
Old 02-28-2007   #1 (permalink)
Imageman
- New homebuilt Vista PC, Vista compatible hardware
- Microsoft Wireless Natural Multimedia Keyboard
- Windows 'Vista' driver software ITP64Eng.exe
If I press the keyboard mute button, the sound slider appears on the monitor
with red, indicating mute, and the sound goes off as it should. If I press
the + or - volume keys, the line turns green, the sound comes back on, but
the volume will not adjust the sound level? In a second or so the control
drops from the monitor? Help appreciated - IM
Old 04-20-2008   #2 (permalink)
Dmeister
Re: Wireless Natural Multimedia Keyboard, No volume control?
I"m having the exact same problem. I have all of the updated patches for
vista (32bit). It is a microsoft wireless natural multimedia keyboard
and the volume control used to work on xp. All I did was update to
vista, download the current drivers from microsoft after installing
vista and volume control (+/-) stopped working. All other controls on
my keyboard (stop, play, pause, etc) work correctly. It's just volume
control.
Dmeister
Posted via http://www.vistaheads.com
Old 04-20-2008   #3 (permalink)
Home premium 32 bit, SP1
Quote  Quote: Originally Posted by Dmeister View Post
control.
Dmeister
Posted via Microsoft Windows Vista Community Forums - Vistaheads
Hello Dmeister,
" other hardware HID Non-User Input Data Filter "-- windows optional update. It is designed specifically for wireless mice and keyboards. If you don't have it installed, you need it. If it's no longer listed in the windows update, install the IntelliPoint software then go look for the optional in windows update. I don't have the link for you, but just type Intellipoint in google search box, you'll see it.
Old 04-20-2008   #4 (permalink)
C.B.
"Dmeister" <Dmeister.385j0s@xxxxxx-mx.forums.vistaheads.com> wrote in message
newsmeister.385j0s@xxxxxx-mx.forums.vistaheads.com...
> control.
> Dmeister
Dmeister,
You may have to uninstall your current software and reinstall it. Below
is the link for the software you need, in English U.S.
http://www.microsoft.com/hardware/mo...indows%20Vista
C.B.
It is the responsibility and duty of everyone to help the underprivileged
and unfortunate among us.
MS Wireless Keyboard no Volume control Vista General
Problem with microsoft natural multimedia keyboard 1.0A Vista General
Volume control doesn't work / MS Natural MM Keyboard Vista hardware & devices
± column control doesn't work / MS Natural MM Keyboard Vista hardware & devices
Some extended keys (Calculator) do not work on Wireless Natural Multimedia Keyboard under Vista (32 bit) Vista hardware & devices
