Logitec Fusion Webcam problem in WLM
  1. #1
    zarralad Guest
    Installed the webcam into Vista and all functions well in standalone, but
    when trying the webcam in Windows Live Messenger I get no audio! I get the
    notice that no audio hardware found. The Sound in Control Panel shows
    Microphone Logitec Mic as working.
    Webcam functioning fine with audio under XP on another machine.
    Any ideas?
  2. #2
    Richard Urban Guest
    Re: Logitec Fusion Webcam problem in WLM
    Did you step through the Audio/Video Tuning Wizard in Messenger live.
    I have the same CAM, as do my two sons. I can assure you that it will, and
    does work, under Vista.
    I did NOT install the Logitech software. Everything that was needed came in
    through Windows Update. Yes, there are now compatible Vista drivers on the
    Logitech website. I downloaded them but haven't needed them.
    Regards,
    Richard Urban
    Quote from George Ankner:
    If you knew as much as you think you know,
    You would realize that you don't know what you thought you knew!
    "zarralad" <zarralad@discussions.microsoft.com> wrote in message
    news:CCBB5F4F-927A-4DFB-9A1A-B08682275A0C@microsoft.com...
    > Any ideas?
  3. #3
    zarralad Guest
    Yes I did. And it all sets up OK.. both video and the mike. But I discovered
    that when I make a phone call only - audio works fine. When I make video call
    - only video works! It gets better.. I installed Skype - and it ALL works..
    so I do not think it is Vista.. it has to be somthing with WLM.
    Thanks for the feeback Richard.
    > Regards,
    > Richard Urban
    > > Any ideas?
Logitec Fusion Webcam problem in WLM problems?
Logitec Microphone unmute help! BruceBLawrence Sound & Audio 0 21 Jul 2008
stop automatic installation of logitec webcam Rene Grothmann Vista installation & setup 0 15 Jun 2008
Net Objects Fusion 10 IDontBelieveIt Vista General 3 29 Apr 2008
Logitec Headphones and microphone Visintini Vista hardware & devices 2 14 Jan 2008
Logitec webcam vista x64 drivers vistaskewl Drivers 1 09 Jan 2007
