| | Help with my Samsung 913t LCD monitor, please ... My monitor will not set up properly ... all I can set is 640 by 480 pixel resolution and Medium (16 bit) colors. Does anyone know where I can get a driver that Vista supports? |
| | Re: Help with my Samsung 913t LCD monitor, please ... Gerry wrote: > My monitor will not set up properly ... all I can set is 640 by 480 pixel > resolution and Medium (16 bit) colors. Does anyone know where I can get a > driver that Vista supports? This is not a function of your monitor drivers. It is a function of your video card drivers. Go to either the video card mftr.'s website or the OEM's website if you have that type of machine (HP, Dell, Sony, etc.) and download/install the video card drivers for Vista. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: Help with my Samsung 913t LCD monitor, please ... "Malke" <notreally@invalid.invalid> wrote in message news:uwlyqPPXHHA.4964@TK2MSFTNGP06.phx.gbl... > Gerry wrote: >> My monitor will not set up properly ... all I can set is 640 by 480 pixel >> resolution and Medium (16 bit) colors. Does anyone know where I can get >> a driver that Vista supports? > > This is not a function of your monitor drivers. It is a function of your > video card drivers. Go to either the video card mftr.'s website or the > OEM's website if you have that type of machine (HP, Dell, Sony, etc.) and > download/install the video card drivers for Vista. The wrong monitor .INF file can certainly prevent you from using the full capabilities of the monitor. It can limit you to lower resolutions or disallow valid resolutions. Tom Lake |
| | Re: Help with my Samsung 913t LCD monitor, please ... Tom Lake wrote: > The wrong monitor .INF file can certainly prevent you from using the full > capabilities of the monitor. It can limit you to lower resolutions or > disallow > valid resolutions. Yes, in certain circumstances with some of the newest monitors using a "non-standard" resolution and aspect ratio. The Samsung 913T is not one of these. However in all the many years I've been a tech I've never had to install a monitor driver on a Windows system. The OP's problems are because he doesn't have the correct video card drivers installed. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | Re: Help with my Samsung 913t LCD monitor, please ... "Malke" wrote: > Tom Lake wrote: > > > The wrong monitor .INF file can certainly prevent you from using the full > > capabilities of the monitor. It can limit you to lower resolutions or > > disallow > > valid resolutions. > > Yes, in certain circumstances with some of the newest monitors using a > "non-standard" resolution and aspect ratio. The Samsung 913T is not one > of these. However in all the many years I've been a tech I've never had > to install a monitor driver on a Windows system. The OP's problems are > because he doesn't have the correct video card drivers installed. > > Malke > -- > Elephant Boy Computers > www.elephantboycomputers.com > "Don't Panic!" > MS-MVP Windows - Shell/User > Thanks for the replies ... I will look into the video card drivers, however .... the monitor was working just fine under XP. Do I need a different driver for Vista? Or did installing Vista cause the system to choose a generic driver instead of the original that I'd been using under XP? One last question ... how do I determine what type video card it is .. and what's the right driver? Thanks in advance for any assistance ... sorry to be such a rookie at all of this ... |
| | #6 (permalink) |
| | Re: Help with my Samsung 913t LCD monitor, please ... Gerry wrote: > Thanks for the replies ... I will look into the video card drivers, however > ... the monitor was working just fine under XP. Do I need a different driver > for Vista? Or did installing Vista cause the system to choose a generic > driver instead of the original that I'd been using under XP? One last > question ... how do I determine what type video card it is .. and what's the > right driver? Thanks in advance for any assistance ... sorry to be such a > rookie at all of this ... Yes, you need drivers for all your hardware for whatever operating system you're running. Vista is a different operating system from XP and so the drivers that worked for XP are not what you want to use in Vista. Do not apologize for being a "rookie". We all had to start somewhere and people like me are here in the newsgroups because we want to help you. Here is general information about drivers: Never get drivers from Windows Update. Get them from: 1. The device mftr.'s website; OR 2. The motherboard mftr.'s website if hardware is onboard; OR 3. The OEM's website for your specific machine if you have an OEM computer (HP, Dell, Sony, etc.). Read the installation instructions on the website where you get the drivers. To find out what hardware is in your computer: 1. Read any documentation you got when you bought the computer. 2. If the computer is OEM, go to the OEM's website for your specific model machine and look at the specs (you'll be there to get the drivers anyway) 3. Download, install and run a free system inventory program like Belarc Advisor. The older Aida32 is good for this, too. http://www.belarc.com/free_download.html - Belarc Advisor http://www.aumha.org/free.htm - Aida32 (hosted on Jim Eshelman's site) Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| | #7 (permalink) |
| | Re: Help with my Samsung 913t LCD monitor, please ... Okay ... I'm up and running ... An e-GeForce FX5200 nvidia graphics card resolved all. Her PC is an older one, with only PCI slots available, so this is the strongest (only 128 MB ), but it's really working fine. She has Aero, and Flip 3D ... a 3.0 experience rating, and is now a "Happy Vista Camper" ... However ... I've still got one issue left to resolve ... our home network has not worked since the Vista installations. Well .. it's kinda worked (all the internet connections work, and we can share printers,) but we can't share files or folders ... I can see the network and the other computers, but attempting to open any other PC's drive or folders (expect for the public ones). I've set no passwords on any machines, and I've set maximum sharing permissions. But still, whenever I try to access a file or folder on a networked PC, I encounter this message --> "\\name\c: is not available. You might not have permission to use this resource. Contact the administrator of this server to find out if you have access permissions. Access is denied. I AM the "administrator of that server" ... but no matter how much I talk to my self (user to administrator) I can't figure out how to allow the sharing to occur. Any suggestions? Thanks in advance ... and oh yeah ... I will accept a "LEAVE ME ALONE, ONLY ONE FIX TO A CUSTOMER!" response !! Thanks again for all the help you've already given Gerry "Malke" wrote: > Gerry wrote: > > > Thanks for the replies ... I will look into the video card drivers, however > > ... the monitor was working just fine under XP. Do I need a different driver > > for Vista? Or did installing Vista cause the system to choose a generic > > driver instead of the original that I'd been using under XP? One last > > question ... how do I determine what type video card it is .. and what's the > > right driver? Thanks in advance for any assistance ... sorry to be such a > > rookie at all of this ... > > Yes, you need drivers for all your hardware for whatever operating > system you're running. Vista is a different operating system from XP and > so the drivers that worked for XP are not what you want to use in Vista. > Do not apologize for being a "rookie". We all had to start somewhere and > people like me are here in the newsgroups because we want to help you. > > Here is general information about drivers: > > Never get drivers from Windows Update. Get them from: > > 1. The device mftr.'s website; OR > 2. The motherboard mftr.'s website if hardware is onboard; OR > 3. The OEM's website for your specific machine if you have an OEM > computer (HP, Dell, Sony, etc.). > > Read the installation instructions on the website where you get the drivers. > > To find out what hardware is in your computer: > > 1. Read any documentation you got when you bought the computer. > 2. If the computer is OEM, go to the OEM's website for your specific > model machine and look at the specs (you'll be there to get the drivers > anyway) > 3. Download, install and run a free system inventory program like Belarc > Advisor. The older Aida32 is good for this, too. > > http://www.belarc.com/free_download.html - Belarc Advisor > http://www.aumha.org/free.htm - Aida32 (hosted on Jim Eshelman's site) > > > Malke > -- > Elephant Boy Computers > www.elephantboycomputers.com > "Don't Panic!" > MS-MVP Windows - Shell/User > |
| | #8 (permalink) |
| | Re: Help with my Samsung 913t LCD monitor, please ... Maybe the help is in here: http://www.microsoft.com/technet/net.../vista_fp.mspx for other PC's http://www.microsoft.com/technet/net..._fp.mspx#EZOAC Ko "Gerry" <Gerry@discussions.microsoft.com> schreef in bericht news:0D1CF675-2F7E-461B-8001-C08C4ABE8B73@microsoft.com... > Okay ... I'm up and running ... An e-GeForce FX5200 nvidia graphics card > resolved all. Her PC is an older one, with only PCI slots available, so > this is the strongest (only 128 MB ), but it's really working fine. She > has > Aero, and Flip 3D ... a 3.0 experience rating, and is now a "Happy Vista > Camper" ... > > However ... I've still got one issue left to resolve ... our home network > has not worked since the Vista installations. Well .. it's kinda worked > (all > the internet connections work, and we can share printers,) but we can't > share > files or folders ... > I can see the network and the other computers, but attempting to open any > other PC's drive or folders (expect for the public ones). I've set no > passwords on any machines, and I've set maximum sharing permissions. But > still, whenever I try to access a file or folder on a networked PC, I > encounter this message --> "\\name\c: is not available. You might not > have > permission to use this resource. Contact the administrator of this server > to > find out if you have access permissions. Access is denied. > > I AM the "administrator of that server" ... but no matter how much I talk > to > my self (user to administrator) I can't figure out how to allow the > sharing > to occur. > > Any suggestions? > > Thanks in advance ... and oh yeah ... I will accept a "LEAVE ME ALONE, > ONLY > ONE FIX TO A CUSTOMER!" response !! > > Thanks again for all the help you've already given > > > Gerry > > > > "Malke" wrote: > >> Gerry wrote: >> >> > Thanks for the replies ... I will look into the video card drivers, >> > however >> > ... the monitor was working just fine under XP. Do I need a different >> > driver >> > for Vista? Or did installing Vista cause the system to choose a >> > generic >> > driver instead of the original that I'd been using under XP? One last >> > question ... how do I determine what type video card it is .. and >> > what's the >> > right driver? Thanks in advance for any assistance ... sorry to be such >> > a >> > rookie at all of this ... >> >> Yes, you need drivers for all your hardware for whatever operating >> system you're running. Vista is a different operating system from XP and >> so the drivers that worked for XP are not what you want to use in Vista. >> Do not apologize for being a "rookie". We all had to start somewhere and >> people like me are here in the newsgroups because we want to help you. >> >> Here is general information about drivers: >> >> Never get drivers from Windows Update. Get them from: >> >> 1. The device mftr.'s website; OR >> 2. The motherboard mftr.'s website if hardware is onboard; OR >> 3. The OEM's website for your specific machine if you have an OEM >> computer (HP, Dell, Sony, etc.). >> >> Read the installation instructions on the website where you get the >> drivers. >> >> To find out what hardware is in your computer: >> >> 1. Read any documentation you got when you bought the computer. >> 2. If the computer is OEM, go to the OEM's website for your specific >> model machine and look at the specs (you'll be there to get the drivers >> anyway) >> 3. Download, install and run a free system inventory program like Belarc >> Advisor. The older Aida32 is good for this, too. >> >> http://www.belarc.com/free_download.html - Belarc Advisor >> http://www.aumha.org/free.htm - Aida32 (hosted on Jim Eshelman's site) >> >> >> Malke >> -- >> Elephant Boy Computers >> www.elephantboycomputers.com >> "Don't Panic!" >> MS-MVP Windows - Shell/User >> |
| | #9 (permalink) |
| | Re: Help with my Samsung 913t LCD monitor, please ... Gerry wrote: > Okay ... I'm up and running ... An e-GeForce FX5200 nvidia graphics card > resolved all. Her PC is an older one, with only PCI slots available, so > this is the strongest (only 128 MB ), but it's really working fine. She has > Aero, and Flip 3D ... a 3.0 experience rating, and is now a "Happy Vista > Camper" ... > > However ... I've still got one issue left to resolve ... our home network > has not worked since the Vista installations. Well .. it's kinda worked (all > the internet connections work, and we can share printers,) but we can't share > files or folders ... > I can see the network and the other computers, but attempting to open any > other PC's drive or folders (expect for the public ones). I've set no > passwords on any machines, and I've set maximum sharing permissions. But > still, whenever I try to access a file or folder on a networked PC, I > encounter this message --> "\\name\c: is not available. You might not have > permission to use this resource. Contact the administrator of this server to > find out if you have access permissions. Access is denied. (snippage) It isn't "one fix to a customer"! ;-) After you check out Koze's good links, take a look also at the following general networking troubleshooting cut/paste to see if anything is applicable to your network since I don't know what operating systems are on your other machines: This is most commonly caused by a misconfigured firewall. Run the Network Setup Wizard on all computers, making sure to enable File & Printer Sharing, and reboot. The only "gotcha" is that this will turn on the XPSP2 Windows Firewall. If you aren't running a third-party firewall or have an antivirus with "Internet Worm Protection" (like Norton 2005/06) which acts as a firewall, then you're fine. If you have third-party firewall software, configure it to allow the Local Area Network traffic as trusted. I usually do this with my firewalls with an IP range. Ex. would be 192.168.1.0-192.168.1.254. Obviously you would substitute your correct subnet. If one or more of the computers is XP Pro or Media Center: a. If you need Pro's ability to set fine-grained permissions, turn off Simple File Sharing (Folder Options>View tab) and create identical user accounts/passwords on all computers. b. If you don't care about using Pro's advanced features, leave the Simple File Sharing enabled. Simple File Sharing means that Guest (network) is enabled. This means that anyone without a user account on the target system can use its resources. This is a security hole but only you can decide if it matters in your situation. Then create shares as desired. XP Home does not permit sharing of users' home directories (My Documents) or Program Files, but you can share folders inside those directories. A better choice is to simply use the Shared Documents folder. Malke -- Elephant Boy Computers www.elephantboycomputers.com "Don't Panic!" MS-MVP Windows - Shell/User |
| Samsung T220 Monitor | Drivers | |||
| Samsung DLP via VGA as second monitor? | Graphic cards | |||
| Where do I get a driver for my Samsung 913T monitor for Vista | Vista hardware & devices | |||
| Samsung 957p Monitor | Vista hardware & devices | |||
| SamSung monitor drivers | Vista hardware & devices | |||
