Vista Tutorial - re.How To Fix The Epson R300 Printer Tray
Old 03-06-2007   #1 (permalink)
Martyn Woodfield
Guest
Hi, To get your Epson R300 printer to print on DVD/CD'S this is what you
have to do. As I'm sure you will know the basic printer drivers are already
in Vista so that is only a matter of pluging in the printer, then to get the
DVD/CD tray working you need to phone Epson on 08704437766 and order the new
software disc Version 1.50 that will cost you £10.00. You will then need
to download from the Epson site a file, it is an XP file strangely enough
but, it is the one that you will need to patch the new software. The file is
EPSON EASYPRINTMODULE 3.0a FILE NUMBER 28265 you need to install this before
the new sotware, if you don't you will get error messages when you try to
launch the DVD/CD printing program.
When you have installed everything and you go to print your Disc it
will come up with an error saying CD PRINTER DRIVER NOT INSTALLED click OK
the printing interface window will come up, you will need to select MANUAL
PRINTING and then ANOTHER WINDOW will appear GO TO PAPER SOURCE AND SELECT
MANUAL click OK and your printer DVD/CD tray will work.
Please let me know if this has helped you and if you want anymore
info on the printer just email me and if I can help I will.
Regards,
Martyn.
Epson R300 Photo Printer Drivers For Vista Drivers
Epson R300 printer Vista hardware & devices
Epson R300 Printer Vista hardware & devices
CD printing on Epson Stylus PHOTO R300 Vista print fax & scan
Epson Stylus Photo R300 (RC1) Vista hardware & devices
