| | Monitor Problems With Recent Vista Install This past weekend i reformated my harddrive and installed windows vista home prem. the problem that iam getting is when restarting and turning on my monitor does not turn on when windows starts up. i can hear the hard drives and dvd-roms goin and doing there thing but nothing comes up on the monitor. once i turn it off by holding down the power button and usually on the 2nd try of turning on, the monitor turns on. i have a 2 y/o dell desktop dim 8800 with a nvidia 256md graphics card. are there any software diag. that i can do to test the boot process if it even recognizes the monitor? |
| | Re: Monitor Problems With Recent Vista Install It may be a power supply or system Bios problem. be sure your BIOS is up to date and you may want to set your BIOS to boot from your CD drive first in order to delay slightly the time when the system tries to boot from you hard drive. "flazz" <flazz@discussions.microsoft.com> wrote in message news:1ACEEE14-D8EE-4734-9D21-8D4FC103FF8D@microsoft.com... > This past weekend i reformated my harddrive and installed windows vista > home > prem. > the problem that iam getting is when restarting and turning on my monitor > does not turn on when windows starts up. i can hear the hard drives and > dvd-roms goin and doing there thing but nothing comes up on the monitor. > once > i turn it off by holding down the power button and usually on the 2nd try > of > turning on, the monitor turns on. > i have a 2 y/o dell desktop dim 8800 with a nvidia 256md graphics card. > > are there any software diag. that i can do to test the boot process if it > even recognizes the monitor? > |
| | Re: Monitor Problems With Recent Vista Install Have you installed the latest drivers for your video card? Sounds like the videocard just isn't telling the monitor to turn on, if it's not a hardware problem in your monitor. Just to be thorough, you could remove and reseat your video card. "flazz" <flazz@discussions.microsoft.com> wrote in message news:1ACEEE14-D8EE-4734-9D21-8D4FC103FF8D@microsoft.com... > This past weekend i reformated my harddrive and installed windows vista > home > prem. > the problem that iam getting is when restarting and turning on my monitor > does not turn on when windows starts up. i can hear the hard drives and > dvd-roms goin and doing there thing but nothing comes up on the monitor. > once > i turn it off by holding down the power button and usually on the 2nd try > of > turning on, the monitor turns on. > i have a 2 y/o dell desktop dim 8800 with a nvidia 256md graphics card. > > are there any software diag. that i can do to test the boot process if it > even recognizes the monitor? > |
| | Re: Monitor Problems With Recent Vista Install Yes, i installed the drivers and windows recognized the card and installed the drivers, i also installed the drivers for the monitor. but still the same problem. "C.Skaggs" wrote: > Have you installed the latest drivers for your video card? > Sounds like the videocard just isn't telling the monitor to turn on, if > it's not a hardware problem in your monitor. > Just to be thorough, you could remove and reseat your video card. > "flazz" <flazz@discussions.microsoft.com> wrote in message > news:1ACEEE14-D8EE-4734-9D21-8D4FC103FF8D@microsoft.com... > > This past weekend i reformated my harddrive and installed windows vista > > home > > prem. > > the problem that iam getting is when restarting and turning on my monitor > > does not turn on when windows starts up. i can hear the hard drives and > > dvd-roms goin and doing there thing but nothing comes up on the monitor. > > once > > i turn it off by holding down the power button and usually on the 2nd try > > of > > turning on, the monitor turns on. > > i have a 2 y/o dell desktop dim 8800 with a nvidia 256md graphics card. > > > > are there any software diag. that i can do to test the boot process if it > > even recognizes the monitor? > > > |
| | I too have a similair problem ive got vista 64 with a core 2 duo e6800 a xfx 8800gtx 2 gb of ddr2 dominator 1066mhz and 760 gig of hard disk space. My problem is when i boot vista normally before the vista windows sign appears the monitor turns off and says i have no signal. So i took it to the shop they said it was a usb conflict fine i thought i will plug them in 1 by 1 and see which 1 affects it, well it worked for a week but yesterday i left the pc for a while and when i came back the monitor is off, so i wiggled the mouse nothing so i reset the pc and the monitor turned off. OK i know what to do take the usb's out (well that didnt work) the monitor still turned off when vista is just about to boot :S right so i though thats wierd i dont want to pay the shop again to be told its a usb problem i will test it on my brother HD tv it boots fine (ok thats really wierd) so i go back to my monitor and try again the monitor turns off (arrgg) what am i doing wrong maybe the monitor is broken? so i boot it in safe mode and it works fine so it cant be the monitor. I uninstall the nvidia drivers and try again to my amazement it boot so i got get the ONLY nvidia vista 64 drivers and re start the machine and guess what? Yes you got it the monitor turns off, so as you can tell ive just about had it with this pc and am asking for help. |
| | #6 (permalink) |
| | Re: Monitor Problems With Recent Vista Install Which drivers are you using for your GTX, there's a beta on nVidia's site 101.41. I have a GTS and not having any problems with it since the 100.65 drivers on Vista x64. "Giler" <Giler.2n3w3a@no-mx.forums.net> wrote in message news:Giler.2n3w3a@no-mx.forums.net... > > I too have a similair problem ive got vista 64 with a core 2 duo e6800 a > xfx 8800gtx 2 gb of ddr2 dominator 1066mhz and 760 gig of hard disk > space. My problem is when i boot vista normally before the vista > windows sign appears the monitor turns off and says i have no signal. > So i took it to the shop they said it was a usb conflict fine i thought > i will plug them in 1 by 1 and see which 1 affects it, well it worked > for a week but yesterday i left the pc for a while and when i came > back the monitor is off, so i wiggled the mouse nothing so i reset the > pc and the monitor turned off. OK i know what to do take the usb's out > (well that didnt work) the monitor still turned off when vista is just > about to boot :S right so i though thats wierd i dont want to pay the > shop again to be told its a usb problem i will test it on my brother HD > tv it boots fine (ok thats really wierd) so i go back to my monitor and > try again the monitor turns off (arrgg) what am i doing wrong maybe the > monitor is broken? so i boot it in safe mode and it works fine so it > cant be the monitor. I uninstall the nvidia drivers and try again to my > amazement it boot so i got get the ONLY nvidia vista 64 drivers and re > start the machine and guess what? Yes you got it the monitor turns off, > so as you can tell ive just about had it with this pc and am asking for > help. > > > -- > Giler |
| | #7 (permalink) |
| | Ive tried them all i even tried the 7900 series drivers as well as the 8800 beta drivers still no joy |
| | #8 (permalink) |
| | Re: Monitor Problems With Recent Vista Install update your mother board bios, i have seen this problem with other o/s your video card slot is not getting told to wake up at startup. updateing your bios should fix the problem "Giler" wrote: > > Ive tried them all i even tried the 7900 series drivers as well as the > 8800 beta drivers still no joy > > > -- > Giler > |
| Recent Hotmail problems - blank replies etc. | Live Mail | |||
| Recent Items drop-down menu problems | Vista General | |||
| Recent Install problems | Vista account administration | |||
| Re: Recent Update Problems | Vista General | |||
