| | Diamond Xtreme Sound No drivers for 64 bit Vista Anyone know a way to install it or have generic drivers? |
| Vista 64 Home Premium | Re: Diamond Xtreme Sound No drivers for 64 bit Vista If you use the TerraTec driver it will work! They both use the C-Media chipset. TerraTec - Driver & Support - TerraTec |
| Vista Ultimate x86 | Re: Diamond Xtreme Sound No drivers for 64 bit Vista Thanks! I downloaded the Aureon 5.1 PCI Driver and Software here: TerraTec - Products - Sound - PCI - TerraTec Then installed the x64 version for Vista and it works perfectly. Vista thinks the application is a legacy app, put just push past UAC and you're in. The XS71 card sounds great and the app gives you all kinds of control and features! Thanks again! P.S. I tried to send a note to Diamond support with this info but their "Contact" page fails when submitting. Too bad for them. |
| Diamond Xtreme Sound No Drivers For Vista 32 Bit | Vista hardware & devices | |||
| New Xtreme Audio & Audigy SE/LS/value drivers released | Sound & Audio | |||
| Im thinking of getting a Creative Sound Blaster X-Fi Xtreme Music card | Sound & Audio | |||
| Vista 64bit and SOund Blaster X-Fi xtreme audio | Sound & Audio | |||
| Sound Blaster X-Fi Xtreme Audio | Vista hardware & devices | |||
