Vista - Problems burning DVDs
Old 03-08-2007   #1 (permalink)
Dr Freon
I have serious problems burning DVDs. If I'm using the Windows DVD burner the
program stops working as soon as the actual burning is to take place. If I
try to do the same using NERO (7.7.5.1) the computer shuts down just like
that. It's a newly built system with a Plextor PX-760A (ATA) DVD-burner. Is
it Vista (Home Premium, Swedish) or could it be that my power supply is to
weak? (PSU 430W, Athlon X2 4600+, GF7600GT, 2GB Ram, 4*320GB in RAID 5, 1 USB
HD, 1 USB Microphone, 1 USB webcam, and 1 GB readyboost USB) Still, there is
no difference weather I disconnect the USBs or not.
Old 03-08-2007   #2 (permalink)
Re: Problems burning DVDs
Nero greatly affects Windows burning. Try uninstaling Nero. (any problem to
do with multimedia or optical drives is probably caused by Nero).
"Dr Freon" <Dr Freon@discussions.microsoft.com> wrote in message
news:4C55F52B-5DF6-47C9-A590-7ED1AECCC2A9@microsoft.com...
>the
> Is
> USB
> is
Old 03-08-2007   #3 (permalink)
C.Skaggs
thats an awful wimpy power supply to be running a x2 on and 4 hard disks
plus 2 gigs of ram.
my guess is that when windows kicks on the laser to burn you get a power
drop out.
Change out that power supply for a 600 watt with at least 2 12 volt rails
and I'll bet you it's fixed.
>the
> Is
> USB
> is
Old 03-08-2007   #4 (permalink)
Uponthis
RE: Problems burning DVDs
Make sure your dvd burner is up-to-date on it's firmware as well.
Old 03-08-2007   #5 (permalink)
Dr Freon
Oh yes it is, latest firmware (1.06). I honestly think it's the power supply.
I need more power!
Old 03-08-2007   #6 (permalink)
Dr Freon
I think you're right. I don't know what I was thinking. I'll actually try to
log the power outtake by the system from the socket first though.
Thank you though!
> plus 2 gigs of ram.
> drop out.
> >the
> > Is
> > USB
> > is
Old 03-08-2007   #7 (permalink)
Gus Kline
Ashampoo DVD burner software works well with Vista. I have it with Vista
Business
> I need more power!
burning DVDs or CDs Vista General
burning DVDs Vista General
Burning dvds Vista music pictures video
problems burning dvds Vista hardware & devices
problems burning dvds in windows vista Vista music pictures video
