| | Driver for Verizon Wireless pc5740 BroadbandAccess PC Card For some reason I have misplaced the drivers for this card. And Verizon only has the the access manager which will not load. The message states "VZAccess Manager requires Windows 98 Second Edition or later." and then aborts installation. When I purchased that card it came with 2 disks one with the drivers and one with the manager. Any suggestions on a fix? or, Will I have to wait for a Verizon to update their manager? Thanks |
| | Re: Driver for Verizon Wireless pc5740 BroadbandAccess PC Card Hi, If you have downloaded the VZAccess Manager then the drivers should be on your system within the VZAccess folder. I believe it would be something like PROGRAM FILES > VZAccess Manager > then a driver folder "BeckyWC" <BeckyWC@discussions.microsoft.com> wrote in message news:FD6CC090-C30A-40B1-99EC-FE5A1A944D13@microsoft.com... > For some reason I have misplaced the drivers for this card. And Verizon > only > has the the access manager which will not load. The message states > "VZAccess > Manager requires Windows 98 Second Edition or later." and then aborts > installation. > > When I purchased that card it came with 2 disks one with the drivers and > one > with the manager. > > Any suggestions on a fix? or, Will I have to wait for a Verizon to update > their manager? Thanks |
| | Re: Driver for Verizon Wireless pc5740 BroadbandAccess PC Card Thanks a lot. I forgot that I had the Windows.old folder that I moved to a netdrive on my network. I just went into the folder that you mentioned and there was a driver folder that had a setup execution file. Worked like a charm. Now I have to setup my modem card so I can access the internet on the go. Now if I can get my wacom intuos 3 tablet driver to work life would be great. I like vista. "Wired4Data" wrote: > Hi, If you have downloaded the VZAccess Manager then the drivers should be > on your system within the VZAccess folder. I believe it would be something > like PROGRAM FILES > VZAccess Manager > then a driver folder > > > "BeckyWC" <BeckyWC@discussions.microsoft.com> wrote in message > news:FD6CC090-C30A-40B1-99EC-FE5A1A944D13@microsoft.com... > > For some reason I have misplaced the drivers for this card. And Verizon > > only > > has the the access manager which will not load. The message states > > "VZAccess > > Manager requires Windows 98 Second Edition or later." and then aborts > > installation. > > > > When I purchased that card it came with 2 disks one with the drivers and > > one > > with the manager. > > > > Any suggestions on a fix? or, Will I have to wait for a Verizon to update > > their manager? Thanks > > |
| | Re: Driver for Verizon Wireless pc5740 BroadbandAccess PC Card Got my Wacom tablet working using the compatibility wizard. Lifes good. "BeckyWC" wrote: > Thanks a lot. I forgot that I had the Windows.old folder that I moved to a > netdrive on my network. I just went into the folder that you mentioned and > there was a driver folder that had a setup execution file. Worked like a > charm. Now I have to setup my modem card so I can access the internet on the > go. > > Now if I can get my wacom intuos 3 tablet driver to work life would be > great. I like vista. > > > "Wired4Data" wrote: > > > Hi, If you have downloaded the VZAccess Manager then the drivers should be > > on your system within the VZAccess folder. I believe it would be something > > like PROGRAM FILES > VZAccess Manager > then a driver folder > > > > > > "BeckyWC" <BeckyWC@discussions.microsoft.com> wrote in message > > news:FD6CC090-C30A-40B1-99EC-FE5A1A944D13@microsoft.com... > > > For some reason I have misplaced the drivers for this card. And Verizon > > > only > > > has the the access manager which will not load. The message states > > > "VZAccess > > > Manager requires Windows 98 Second Edition or later." and then aborts > > > installation. > > > > > > When I purchased that card it came with 2 disks one with the drivers and > > > one > > > with the manager. > > > > > > Any suggestions on a fix? or, Will I have to wait for a Verizon to update > > > their manager? Thanks > > > > |
| Vista won't recognize Verizon wireless card | Drivers | |||
| Verizon wireless card and Vista Beta 2 | Vista hardware & devices | |||
| Verizon wireless card and vista beta 2 | Vista installation & setup | |||
| Verizon Wireless PC5740 Broadband card | Vista hardware & devices | |||
| verizon wireless card | Vista General | |||
