no sound after Vista
  1. #1
    elcobre Guest
    I have a HP Pavilion dv8000; after I upgrade to Vista, the HD audio is
    disable; I can not find any update and windows is telling me there isn't any;
    is that the case? I downloaded one from HP, that I thought it could have
    help; but, could not be installed. can anybody help? or, should I trow VISTA
    awy?
  2. #2
    Cari \(MS-MVP\) Guest
    Re: no sound after Vista
    HP should have one at their website. Try their update utility:
    http://h10025.www1.hp.com/ewfrf/wc/g...c00862982#N315
    Cari (MS-MVP)
    Windows Technologies - Printing & Imaging
    http://www.coribright.com/windows
    "elcobre" <elcobre@discussions.microsoft.com> wrote in message
    news:5547405F-655F-437B-B855-00C6AD18CACA@microsoft.com...
    > any;
    > VISTA
    > awy?
  3. #3
    FirstNational Guest
    On Mar 9, 6:01 pm, elcobre <elco...@discussions.microsoft.com> wrote:
    > I have aHPPaviliondv8000; after I upgrade toVista, the HD audio is
    > is that the case? I downloaded one fromHP, that I thought it could have
    > help; but, could not be installed. can anybody help? or, should I trowVISTA
    > awy?
    I have the same problem you stated. I just upgraded the other day.
    Did you ever find a solution?
  4. #4
    MacLynn56 Guest
    RE: no sound after Vista
    It appears Vista is the problem. I also have a Pavilion a1750e it came with
    Vista. After having no luck with the onboard sound, I bought a Sound Blaster
    Audigy SE. After installing and loading drivers and software, I found I was
    still without proper sound. After investigating I was told a third party
    program called Total Recorder would work as it bypasses the sound card and
    manipulates the sound directly from the PC. This also did not work.
    Roxio claims that the problem is with Vista. It handles sound completely
    differently than any other Windows Operating System. Of course if they have
    known that was the case, why are they selling products as " Vista compatible
    " when they are clearly not ? They assure us they have a team of developers
    working on a solution.
    In the meantime, it looks like we will have to accept Vista the way it
    stands, or go back to another OS.
    If anyone has a sloution, PLEASE don't hesitate to let us know.
    Thank you.
    > awy?
  5. #5
    sammie3601 Guest
    I have a gateway mx6454....vista compatible....bought it with that.....no
    sound....it says in the device, it is there no problem. but in audio it says
    no divice in stalled. hhheeellllppp!!
    please can someone help
    > awy?
  6. #6
    Jack K Guest
    "sammie3601" <sammie3601@discussions.microsoft.com> wrote in message
    news:29AB6EC8-48F8-4506-95EA-99D0D0014B60@microsoft.com...
    > says
    >> any;
    >> VISTA
    >> awy?
    I have a Sony Vaio VGN-FE45G/W and if I use the sleep mode, the sound is
    often lost after coming out of "sleep". So, AVOID using the sleep mode!
    Microsoft has published a fix for this KB929685, but when I try and install
    it, I get a message that says: "The update does not apply to your system". I
    did use the correct version (32 bit) of KB929685:
    http://support.microsoft.com/kb/929685/
    So I'm not sure why my no audio with Vista problem shouldn't respond to
    KB929685?
    Anyway, I tried doing this:
    Control Panel: System: Device Manager: Sound video and game controllers:
    expand and right click on high definition audio device: then uninstall the
    driver. Then put the computer to sleep and power up again and the driver is
    reinstalled. This worked OK, but then since that time, if I use the sleep
    mode again, the sound is sometimes lost again. So I went through the
    uninstall procedure again, and went in and out of sleep, and it still didn't
    bring the sound back. GRRRR... but after a couple of complete power downs
    and reboots, the sound did reappear! So this uninstallation trick doesn't
    always work and persistence is needed!
    Uninstalling and reinstalling drivers is often the first step in solving
    lack of sound (and other) problems, but my post may not work for your HP
    problem?
  7. #7
    manilaboyph Guest
    My Asus Motherboard is P4V800D and my Operating System is Vista Ultimate
    about my Mainboard no ADI codec is install about SOUNDMAX AD1888 codec any
    upgrade about the vista ultimate OS for my PC pls e-mail me about this
    matter THANK YOU and GOD BLESS!!!
    "MacLynn56" <MacLynn56@discussions.microsoft.com> wrote in message
    news:41501EC4-E5E3-4C98-A872-41228177820B@microsoft.com...
    > with
    > Blaster
    > was
    > have
    > compatible
    > developers
    > Thank you.
    >> any;
    >> VISTA
    >> awy?
no sound after Vista problems?
distorted sound in vista/createiv x-fi titanium sound card badperson Sound & Audio 1 03 Sep 2009
Low sound from speakers and no windows sound on new vista Karen Vista hardware & devices 2 24 Mar 2007
Laptop Sound card + Vista - NO SPEAKERS!! + NO SOUND FriarTuck91 Vista hardware & devices 0 04 Nov 2006
My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! Kevin John Panzke Vista General 1 14 Oct 2006
Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) Terje Alexander Barth Vista General 0 14 Oct 2006
