| | Radeon X1300 Display not visible after HDTV source switch or power cycle I've got a new entry on my Vista experience blog http://blog.360.yahoo.com/blog-vbgL8XY7cqudqaIlm11BqaTz andjust logged this ticket with ATI and wondered if anyone else has experienced this and has a better workaround or solution. I have a Dell Dimension XPS410 and the X1300 graphics card is connected via a dvi to hdmi cable to a Sony Grand Wega 55" HDTV as the sole monitor. The display works fine when the pc is powered, however when the TV is powered off and back on or the input changed on the TV I get not video until the PC is rebooted or the display cable is disconnected and then reconnected. f I pull the cable and reattach then the display becomes visible and changes to a smaller screen size setting and then I have to redefine the screen size. I attached a second monitor (analog) in a cloned and extended display configuration and that display remained functional when the dvi digital one did not. After the digital display went blank I was able to recover by repeating the Catalyst display setup although I have to do this every time the digital HDTV display is powered off or input changed. From this ATI KB it looks like I am not alone. http://support.ati.com/ics/support/d...estionID=20848 A workaround I am going to try it to use a DVI-I to COMPONENT cable I just bought on eBay. -- news1@jlawson.org mst3k#3801 http://www.jlawson.org "A seminar on time travel will be held 2 weeks ago" |
| Radeon X1300 | Vista hardware & devices | |||
| Radeon X1300 socket? | Vista hardware & devices | |||
| Vista 64 w/ Radeon 9550 AGP and Radeon X1300 PCI | Vista hardware & devices | |||
| ATI Radeon X1300 problems | Vista hardware & devices | |||
| Radeon X1300 256 Vista Driver | Vista General | |||
