Vista - Problems with xfx 8800 gtx and Vista!!!!
Old 03-11-2007   #1 (permalink)
mc_nes
Hello, I am experiencing crashes in all the games that I own. I am running
a XFX 8800 GTX XXX Edition, for a display adaptor, and using Windows Vista
Home Premium. Before I installed this video card, I was using a Nvidia 7300
LE. The previous card gave me no problems. Initially, I installed the 8800
GTX XXX on a computer using Windows XP/Media Center as an Operating System
and I encountered the same problem with game crashes. So I don't think this
problem. specific to Vista Home Premium.
When I decided to build a custom gaming/music producing rig I opted for
higher performance parts and decided to go with Vista Home Premium. I
installed the 8800 GTX XXX and all of my new hardware, plus an additional GB
of ram, for a total of 2 GB.
The problem is any game that I play, besides dungeon siege 2, will
eventually freeze up, during gameplay, the screen will go black for about two
minutes, and then a blue screen with the following error code results:
Technical Information:
STOP: 0x00000116 (0x9CBEBBA0, 0x8B6E29A0, 0x00000000, 0x00000002)
nvlddmkm.sys - Address 8B6E29A0 base at 8B6DE000, DataStamp 45e829......
Is there a patch or a hotfix that I have missed? I do have all the latest
drivers from Nvidia and from Asus, as far as bios is concerned. I have a
'ticket' with Xfxforce.com's Support Center for this issue and they are
working with me but I would appreciate the help and other angles. Thank you.
Old 03-11-2007   #2 (permalink)
mc_nes
RE: Problems with xfx 8800 gtx and Vista!!!!
Ooops, I forgot my specs..... here you go!
Intel Core 2 Duo E6700(@ 2.66Ghz, 4MB L2 Cache,1066 FSB)
Asus P5N-E SLI Motherboard
2GB RAM (x2 1Gig 566Mhz Dell Modules)
Western Digital 320Gig HDD
Western Digital 160Gig HDD
Sound Blaster X-fi Elite Pro
BFG 800W PSU (4)+12V/ 18A
Old 03-11-2007   #3 (permalink)
pvdg42
Re: Problems with xfx 8800 gtx and Vista!!!!
"mc_nes" <mc_nes@discussions.microsoft.com> wrote in message
news:12FB0450-76A9-4B7E-9E78-CC4A5B8185EB@microsoft.com...
> running
> 7300
> 8800
> this
> GB
> two
> you.
Have you checked in/posted in the NVIDIA forums? As you said, the problem is
not Vista-unique, and the NVIDIA forums are a good place to look for
hardware/driver issues and solutions.
http://forums.nvidia.com/
Old 03-11-2007   #4 (permalink)
Steve Jain
On Sun, 11 Mar 2007 17:52:03 -0700, mc_nes
Have you updated to the latest nVidia Beta drivers, 101.41? They
solve a lot of problems.
Cheers,
Steve Jain, Virtual Machine MVP
http://vpc.essjae.com/
Old 03-12-2007   #5 (permalink)
Rik
I have had similar problems with xfx geforce 6800 XT, in XP MCE 2005. The
games i play freeze but do eventually recover for a few seconds before
freezing again. Also the MCE live tv does exactly the same. The only thing i
can find to recover the tv is to restart and for it to be the only program to
run from startup, and it lasts ten minutes before it starts to freeze again.
> Cheers,
Old 03-12-2007   #6 (permalink)
CrimLiar
"mc_nes" <mcnes@discussions.microsoft.com> wrote in message
news:170C8E59-09C9-428B-888A-801ED598B5AE@microsoft.com...
I have an almost identical system here:
4GB RAM (x4 1Gig 800Mhz OCZ Modules)
4x Seagate 500G HDDs (1+0 Array)
2x BFG 8800 GTX
BFG 1000W PSU
**All fitted in a Thermaltake VA8003BWS Armour Super Tower case (the one
with the 25CM!!! fan on the side, and a second drive bay 10cm fitted).
The video cards on my rig can tend to get very hot, I'm wondering if the
case you are using (what case are you using) is up to the job of keeping the
overclocked XFX cards properly chilled. If you can get the (some what
buggy) nTune utility to run, what sort of temperatures is it reporting?
Crimliar
Old 04-26-2007   #7 (permalink)
AlKolkin
Various websites and a potential law suit talk about the problem of using the
8800 Series with Vista. When running DreamScene, DirectX 10.0 demos, and
video DVD's, a message pops up saying that Nvlddmkm.dll or nvlddmkm.sys has
lost connectivity and has been recovered. In some cases the computer has to
be rebooted and the offending programs not run again. In some cases, there
is a BSOD or other error messages.
Many solutions, including driver updates and elimination of older versions
of the drivers have been suggested. None of them work.
Well, for me the problem appears fixed; I simply turned off UAC!!!!!!!!!!!!
Everything has been running fine for an hour, which is a record.
My setup is as follows:
* Hardware and software firewall, antispyware, and anti virus software
* Asus Striker Extreme
* PNY 8800 GTX -- Driver version 7.15.11.5818 (158.15)
* 2 GB Corsair Dominator memory
* OC the CPU to 3.00 MHz
* Two Raptor RAID 0 drives
* External RAID 5 backup
* Creative X-Fi gamer
I really hope that this post helps people.
> > Cheers,
8800 GTS Driver Problems Drivers
8800 GTX vista x64 drivers Graphic cards
problems when using 8800 Gts cards Graphic cards
8800 GTS 640mb or 8800 GT 512mb SLI? Graphic cards
Anyone with a GeForce 8800 GTS under Vista 64-bit? Vista hardware & devices
