Vista - To all with HP/Compaq Audio Problems
Old 06-12-2006   #1 (permalink)
Thracky
Hello all,
Here's what I've figured out thus far.
There is currently NO possible way in my knowledge to get any drivers
working with x64 Vista with the Conexant audio chips, which is what everyone
who is having issues has on their respective notebooks. However, there's a
lot more hope if you can cope with only running the x86 Vista ;-)
Basically as far as I can tell the standard xp drivers should work just fine
as I am using them right now on a Compaq V2575 which uses the Conexant
AC-Link Audio. Download the respective driver from the HP website for your
model, generally the file you download will be a self-extracting archive that
will pop itself somewhere (Usually C:\swsetup\some subdir) and then it will
automatically run the program to install the drivers itself, cancel that
program, find the program (or any and all exe's for that driver package in
the swsetup directory) and make sure that you set windows xp with service
pack 2 compatibility for them.
I'm sure manually installing the drivers would also work, so really either
way there should be no issue with sound as long as you're willing to stick
with x86 for now.
Old 06-13-2006   #2 (permalink)
BeckyWC
RE: To all with HP/Compaq Audio Problems
I have the hp zd8000 and I have sound. I forgot where on the internet I went
to to get vista beta driver for a conexant ac'97 or realtek ac'97.
I don't know which audio chip you have but don't give up. Try here
http://www.planetamd64.com/lofiversi...hp/t15832.html
"Thracky" wrote:
> Hello all,
> with x86 for now.
Old 06-13-2006   #3 (permalink)
Roy Coorne
Re: To all with HP/Compaq Audio Problems
I went to the Windows Update within the Vista Control Panel (!) and
from there the driver for my Realtek AC'97 on-board sound was
downloaded and installed.
Roy
Old 06-13-2006   #4 (permalink)
Thracky
I had already tried the Realtek Vista beta drivers and everytime I tried to
install them in x64 vista I would get a "The path cannot be found" error when
it tried to install the driver. I however never tried the whole intel ac97
workaround that they were explaining in that thread, however I did notice
that someone had mentioned they couldn't get it to work in vista, as it was
primarily an xp x64 workaround.
I'd be interested to hear exactly what driver you used (and which audio chip
your particular zd8000 has, I used to sell these things so I know there's a
ton of submodels of the zd8000 hehe) and what process you used to make it
work, but I've already gone through the trouble of installing x86 vista so
this is probably more just for my peace of mind at this point as i'm not
really wanting to go through the whole 2-3 hour install again.
> "Thracky" wrote:
> > Hello all,
> > with x86 for now.
Old 06-13-2006   #5 (permalink)
Flybynight
I have an HP Pavilion dv5035 and also had problems with my AC97 audio and
modem (same hardware I believe). My issue now is after problems with Vista,
I uninstalled it from a separate partition. Now my Audio and Modem are no
longer found. XP simply does not recognize that the devices are even
installed. I tried rolling back the regestry, but no luck there either.
Old 06-13-2006   #6 (permalink)
Alec
I have hp a1320n and i went and updated beta drivers ac-97. i have sound but
I cant control my inputs chg inputs they are all on. cant mute anything but
master volume under xp everything worked. Do i need to d/l something else.
I have the 6060 version of drivers
Old 06-17-2006   #7 (permalink)
Charlie V
Hello,
I'm just about to solder in a new audio (Vista) chip into my HP Pavilion
ze5375us Notebook..! Same problem with the Conexant AC-Link Audio. No Audio..
I've tried every which way to get that driver from HP to install. I tried
the Audio64.zip with the command line.. No good either. I tried 6 other
drivers 10 different ways..Same result.. Help is on the way........Read on..
I finally got a hold of a good HP tech who is "Very aware" of this issue
with Vista. He said that HP is "presently" working on and going to release a
driver shortly that will solve this issue. So check their site for it.
Charlie V
"Thracky" wrote:
> Hello all,
> with x86 for now.
Old 06-17-2006   #8 (permalink)
Charlie V
Hello,
I'm just about to solder in a Vista Audio chip into my HP Pavilion
ze5375us..!!! No Audio drivers for "Conexant AC-Link Audio". I've tried 10
different drivers 10 different ways...Same result.. No Audio. Sooooooo.....
I was lucky and got a hold of a good HP Tech today and he said that HP is
"very aware" of this Conexant AC-Link Audio driver issue with Vista. A driver
is in the works at HP right now. He felt that it will be posted on HP's
download site pretty soon. HP is receiving hundreds of emails and calls
everyday about this.
That's good news. Check HP's site for the released driver. It shouldn't be
too long according to the tech.
Have a good one..! Charlie V
"Thracky" wrote:
> Hello all,
> with x86 for now.
Old 06-24-2006   #9 (permalink)
John Brutovsky
I have a m7160n Media Center PC and had the same sound issues. I went to the
HP website and downloaded and installed the latest XP updated drivers for my
computer while running Vista, and now my Vist a has sound.
"Thracky" wrote:
> Hello all,
> with x86 for now.
Old 06-25-2006   #10 (permalink)
allvuong
Installing the drivers from the hp website works with the 32 bit vista, but
not 64 bit vista, buts thats the last time i check, there may be new that i
dont know, but thats what i experienced.
> "Thracky" wrote:
> > Hello all,
> > with x86 for now.
Audio Problems Vista hardware & devices
If you have a HP Laptop and No Audio Drivers/Audio Problems Vista hardware & devices
SoundMAX Integrated Digital Audio on HP Compaq nc4200 problem Vista hardware & devices
Non Working Audio on COmpaq Presario B3817 Vista hardware & devices
Compaq 910US no audio Vista hardware & devices
