Vista - Dual use of LCD monitor
Old 03-12-2007   #1 (permalink)
Rbrummy
I have a new Vista computer and an older XP computer. Both are not used at
the same time. I have an LCD monitor with both a digital and an analog
connection. Could I have the XP computer connected to the analog connection
and the Vista computer connected to the digital connection and use the
monitor with both computers as long as only one computer is powered up?
Old 03-12-2007   #2 (permalink)
Dominic Payer
Re: Dual use of LCD monitor
Usually there is a front panel selector to allow choice of inputs. Selection
is automatic if only one input is active.
Both computers can run simultaneously, but only one computer's display can
be shown on the screen. It's your choice which, and you can switch as you
like.
"Rbrummy" <Rbrummy@discussions.microsoft.com> wrote in message
news:08747AAF-C432-4D35-B110-9941E482BF06@microsoft.com...
> connection
Old 03-12-2007   #3 (permalink)
Lilo Lentz
Exactly how is that done?
I'm asking cuz I tried using only the digital connection and nothing
worked...
For my Samsung SyncMaster 940BF only the analog connection seems to work...
Lilo
"Dominic Payer" <dcp@fsv.co.uk> skrev i meddelelsen
news:44E999AE-A8E2-40CF-A764-68592B291A26@microsoft.com...
> Selection is automatic if only one input is active.
> like.
>>at
>> connection
Old 03-12-2007   #4 (permalink)
Dominic Payer
Your manual will tell you which is the source selection button.
Check that the DVI cable is undamaged and securely inserted.
The graphics card driver may need specific setup instructions to output to
the DVI connector.
It is possible that the DVI connector to your monitor or graphics card is
faulty. Go through all the official troubleshooting steps specified in your
manual.
"Lilo Lentz" <misslilo@hotmail.com> wrote in message
news:ODfk36LZHHA.3928@TK2MSFTNGP03.phx.gbl...
> worked...
> work...
> Lilo
>> can be shown on the screen. It's your choice which, and you can switch as
>> you like.
>>>at
>>> connection
Dual monitor help General Discussion
Dual Monitor Help Vista General
Dual monitor Vista hardware & devices
Dual monitor Vista General
Dual monitor bug Vista mail
