Just looking for experience with USB flash drives for readyboot. I've read
that its recommended to match the USB capacity with the computer RAM size.
it is true?
Any brand/model for recommend ?
Pls share your experience!!
thanks in advance.
it is true?
thanks in advance.
When I purchased my Vista Upgrade (Ultimate,) staples was giving a free PNY
Attache flash drive away with the upgrade purchase. It is a 1GB drive and
works well for readyboost. I have 2GB on board on my machine. The only
sizing reccommendations that I have heard regarding Readboost devices was
that it is using your flash drive, instead of your hard drive, to store
temporary files. So here I guess, bigger is better to some limit. Who knows
what the limit is?
Benny
> it is true?
> thanks in advance.
I'm using a Patriot 4GB. If you are buying a USB drive for ReadyBoost only,
I'd recommend upping your RAM instead. If you are using it for a portable
storage device as well, then I'd go for a 2 - 4 GB drive.
With 1 GB of physical RAM, it does make a difference. When I use 2 GB of
physical RAM, it is a lot less noticeable.
Dustin Harper
dharper@vistarip.com
http://www.vistarip.com
"jlocatell" <jlocatell@datamarkets.com.ar> wrote in message
news:%23kxZwoaZHHA.3520@TK2MSFTNGP04.phx.gbl...
> it is true?
> thanks in advance.
I have a PNY U3 attachie flash drive and I showed a size to use so I went
with recommended. That's the best way to go in my opinion.
"Dustin Harper" <dharper@vistarip.com> wrote in message
news:BE9953F8-9F12-43E7-AEF8-F302FED95BC1@microsoft.com...
> only, I'd recommend upping your RAM instead. If you are using it for a
> portable storage device as well, then I'd go for a 2 - 4 GB drive.
> Dustin Harper
>> read that its recommended to match the USB capacity with the computer RAM
>> size. it is true?
>> thanks in advance.
Sorry I ment that what windows recommened for it.
"Amrykid" <amrykid@gmail.com> wrote in message
news:57445D9D-23B3-4CE8-9217-B0E44ED1D965@microsoft.com...
>> Dustin Harper
>>> RAM size. it is true?
>>> thanks in advance.
| Similar Threads | ||||
| Flash Drive has no drive letter... Not in Disk Management | mattperry | Vista hardware & devices | 12 | 13 Jan 2009 |
| Question about ReadyBoot (Not ReadyBoost) | Everlong | General Discussion | 6 | 19 Aug 2008 |
| Pen drive/USB flash drive showing as floppy disk | Mark Bates | Vista General | 0 | 24 Mar 2008 |
| LastWriteTime and Locating the drive letter of a flash drive. | Fred J. | PowerShell | 4 | 12 Jul 2007 |
| Readyboot - MS | Bren | Vista performance & maintenance | 0 | 21 Feb 2007 |
