| | BSOD - Vista 64 bit Home premium - Please help :( Problem caused by Device Driver You received this message because a device driver installed on your computer caused the Windows operating system to stop unexpectedly. This type of error is referred to as a "stop error." A stop error requires you to restart your computer. More information -------------------------------------------------------------------------------- Problem report summary Problem type Windows stop error (a message appears on a blue screen with error code information) Solution available? No What does this problem mean? Windows has encountered a problem it cannot recover from and it needs to be restarted Cause Unknown Computer symptoms A message appears on a blue screen with error code information (for example: 0x0000001E, KMODE_EXCEPTION_NOT_HANDLED) Additional steps for you to take Please continue to send problem reports so analysts at Microsoft can study and try to correct the problem as quickly as possible Product Windows Problem Shut down unexpectedly Date 12/03/2007 08:46 Status More information available Problem signature Problem Event Name: BlueScreen OS Version: 6.0.6000.2.0.0.768.3 Locale ID: 2057 Files that help describe the problem (some files may no longer be available) Mini031207-01.dmp sysdata.xml Version.txt Extra information about the problem BCCode: 24 BCP1: 00000000001904AB BCP2: FFFFF98000C59248 BCP3: FFFFF98000C58C20 BCP4: FFFFF80001883C7E OS Version: 6_0_6000 Service Pack: 0_0 Product: 768_1 Server information: dfcdd886-f454-4208-aaaa-7ff2b4c91bed |
| BSOD + DMP File (Vista Home Premium x86) | Vista General | |||
| BSOD upon Vista Home Premium Install | Vista installation & setup | |||
| Vista Home Premium x64 BSOD caused by netio.sys | Vista performance & maintenance | |||
| BSOD in Vista Home Premium SP1 | Vista General | |||
| Flight Simulator X w/ Vista Home Premium=BSOD | Vista Games | |||
