Vista - Vista automatic driver installation problem
Old 03-14-2007   #1 (permalink)
ejunks
Hello,
I am having problems in the automatic driver installation in windows
vista...
When i install vista freshly,the automatic detection and installation of the
drivers works perfectly,
but after a few days of use ,this feature doesnt work correctly,and I have
to point to the driverstore directory to search for the drivers...and in
this case it finds the drivers and installs it correctly.
very common peripherals like flash disks also dont get automatically
installed...
and i am not the only person facing this...look at the following link..
http://groups.google.com/group/micro...6718971b6e73cf
any help in correcting this problem will be appreciated..
Thanks.
Old 03-14-2007   #2 (permalink)
Efrem Moraes
RE: Vista automatic driver installation problem
I am having the exact same problem.
"ejunks" wrote:
> Hello,
> vista...
> installed...
> Thanks.
Old 03-27-2007   #3 (permalink)
Hitechmx
My solution this problem , uninstall all applications of NOKIA ( in my Case)
, now works fine all devices usb reconognised by Xp , (mouses wireless works
fine, usb
acteck portatil speakers, hub usb 2.0 generic, and several hard disk external
usb)
Erick, sorry my english
> "ejunks" wrote:
> > Hello,
> > vista...
> > installed...
> > Thanks.
Driver installation problem Network & Sharing
disable automatic driver installation? Drivers
Bluetooth driver install KILLED automatic driver installation Vista hardware & devices
automatic driver installation problem in vista rc2 Vista General
