Hi
I just installed my ATI Radeon X1950PRO graphic card.
The drivers and Catalyst Control Panel 7.2 installed ok after several tries.
However - I CAN'T get the Windows Experience Index to update without the
screen going black and Graphic card fan going nuts. I have to do a hard
Reboot.
I suspect it to be the 3D settings...
Questions about my cards 3D options:
1: Should I deactivate the 3D Catalyst A.I?
2: Would it help to Uncheck the support for DXT textureformats?
Also - my card has 2 outlets for power.. I only used 1.
Does that make a difference?
I only have 1 monitor - Samsung SyncMaster 940BF
ASUS P4P800-E Deluxe
2GB RAM
Vista Business
lilo
