Vista - Vista - Wireless network connection
Old 03-17-2007   #1 (permalink)
John
I have a new HP notebook with a Wireless network adapter, and Windows home
Premium installed. After a couple days of reasonable operation, suddenly
the wireless adapter is no longer connecting. The WEP setting is the same,
as is the ip setting, gateway, etc. I would say it has something to do with
the WEP setting since it will connect with other access points that are
unsecured.
Does anyone have any ideas? I'm afraid that Vista is too screwed up for me
to figure out.
John
Old 03-18-2007   #2 (permalink)
Cari \(MS-MVP\)
Re: Vista - Wireless network connection
The first obvious thing to try would be a System Restore to the point where
it worked OK. My notebook has never lost its access in this household...
nor has the wireless desktop. Did you check your router is still
functioning? Can other wireless PCs connect OK?
Cari (MS-MVP)
Windows Technologies - Printing & Imaging
http://www.coribright.com/windows
"John" <John@home.com> wrote in message
news:xfOdnReqjYBtPWHYnZ2dnUVZ_o-knZ2d@comcast.com...
>with the WEP setting since it will connect with other access points that
>are unsecured.
> me to figure out.
> John
Old 03-22-2007   #3 (permalink)
countryhouse
I am able to duplicate this problem at will. If I turn off the security
settings for the wireless connection, I am able to connect using the Vista
notebook. When I turn the WEP settings back on, the Vista notebook can no
longer connect, but my XP wireless notebook can connect, as can my XP
wireless desktop.
If I do an ipconfig /all, it shows that the wireless adapter is
disconnected. If I try to renew or release, it says that these things
cannot be done because the adapter is disconnected.
John
"Cari (MS-MVP)" <NewsGroups@coribright.com> wrote in message
news:%23KfN3%23RaHHA.5032@TK2MSFTNGP02.phx.gbl...
> where it worked OK. My notebook has never lost its access in this
> household... nor has the wireless desktop. Did you check your router is
> still functioning? Can other wireless PCs connect OK?
> Cari (MS-MVP)
>>same, as is the ip setting, gateway, etc. I would say it has something to
>>do with the WEP setting since it will connect with other access points
>>that are unsecured.
>> me to figure out.
>> John
Connecting Vista VPN drops wireless network connection Vista networking & sharing
Losing wireless connection to specific wireless network Vista networking & sharing
Wireless network establishs a public network connection Vista networking & sharing
Why can my wired Vista connection not see my wireless network setu Vista networking & sharing
Vista & XP Home Wireless Network Connection Please Help! Vista networking & sharing
