| | Keep losing my sound I bought a new Dell Dimension E521 computer about 2 weeks ago with Vista Home Premium on it. The sound card is on board and is a Sigma Tel High Definition Audio Codec. (Well that's what it says on my speaker icon.) A few days after using the computer, I noticed I lost my sound so I called Dell tech and I don't think they found anything wrong. After being on the phone with them for quite some time, he told me to reboot my computer. In doing this, I had my sound back so I figured all was fine. A few days later, I lost my sound again but didn't call Dell. I just rebooted and got my sound back. After the second time I lost sound, I did receive a message that there were new sound drivers so I installed them and hoped this would stop this no sound from happening again but it didn't. I've lost sound two more times. I'm not sure what I'm doing or what I've done when the sound goes. I don't always realize it when it first happens since not everything you do on the computer gives you a sound but each time I lose the sound, all I have to do is reboot and it's back. This is not normal and I don't know if it's a Vista problem, or a problem with my Dell computer. Before I try calling Dell, I thought I'd see if anyone here has any ideas. And one more thing. This happened this morning when I first turned on my computer, before I did anything on the computer. I booted it up and walked away to do something. When I came back I had an error saying my slide show screen saver couldn't start. I then clicked on my mail and realized there was no bell when my e-mails came in which meant I had no sound so I rebooted, and got the sound back. Could the slideshow screen saver be causing this? That's the only connection to the problem I know about. Sheryl |
| | Re: Keep losing my sound Sheryl wrote: > I bought a new Dell Dimension E521 computer about 2 weeks ago with > Vista Home Premium on it. > The sound card is on board and is a Sigma Tel High Definition Audio > Codec. (Well that's what it says on my speaker icon.) > A few days after using the computer, I noticed I lost my sound so I > called Dell tech and I don't think they found anything wrong. After > being on the phone with them for quite some time, he told me to > reboot my computer. In doing this, I had my sound back so I figured > all was fine. A few days later, I lost my sound again but didn't call > Dell. I just > rebooted and got my sound back. After the second time I lost sound, I > did receive a message that there were new sound drivers so I > installed them and hoped this would stop this no sound from happening > again but it didn't. I've lost sound two more times. I'm > not sure what I'm doing or what I've done when the sound goes. I > don't always realize it when it first happens since not everything > you do on the computer gives you a sound but each time I lose the > sound, all I have to do is reboot and it's back. This is not normal and I > don't know if it's a Vista problem, or a > problem with my Dell computer. > Before I try calling Dell, I thought I'd see if anyone here has any > ideas. And one more thing. This happened this morning when I first > turned on my computer, before I did anything on the computer. > I booted it up and walked away to do something. When I came back I > had an error saying my slide show screen saver couldn't start. I then > clicked on my mail and realized there was no bell when my e-mails > came in which meant I had no sound so I rebooted, and got the sound > back. Could the slideshow screen saver be causing this? That's the only > connection to the problem I know about. > Sheryl There's almost no other way to deal with this than trial and error. Boot the system, be sure the sound is working, then go through your normal routine, checking the sound after each thing you do and that includes simply opening and closing applications. You might start with the following, think about anything you've added to the system, anything you've installed on the laptop since you got it, any applications, open or run them, check the sound, close them, check the sound and see if you anything triggers it. If yes, reboot and try again with the same application to see if it repeats, if yes, you've likely found the culprit. After you find it, you may still want to check other things to be sure they aren't at issue as well. -- Michael Solomon |
| | Re: Keep losing my sound Return your computer for repair or replacement. A two week old system should not require this kind of user intervention. -- Richard G. Harper [MVP Shell/User] rgharper@gmail.com * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ * PLEASE post all messages and replies in the newsgroups * The Website - http://rgharper.mvps.org/ * HELP us help YOU ... http://www.dts-l.org/goodpost.htm "Sheryl" <sheryltoo@snet.net> wrote in message news:ur9QQh7aHHA.596@TK2MSFTNGP06.phx.gbl... >I bought a new Dell Dimension E521 computer about 2 weeks ago with Vista >Home Premium on it. > The sound card is on board and is a Sigma Tel High Definition Audio Codec. > (Well that's what it says on my speaker icon.) > A few days after using the computer, I noticed I lost my sound so I called > Dell tech and I don't think they found anything wrong. After being on the > phone with them for quite some time, he told me to reboot my computer. In > doing this, I had my sound back so I figured all was fine. > A few days later, I lost my sound again but didn't call Dell. I just > rebooted and got my sound back. After the second time I lost sound, I did > receive a message that there were new sound drivers so I installed them > and hoped this would stop this no sound from happening again but it > didn't. > I've lost sound two more times. I'm not sure what I'm doing or what I've > done when the sound goes. I don't always realize it when it first happens > since not everything you do on the computer gives you a sound but each > time I lose the sound, all I have to do is reboot and it's back. > This is not normal and I don't know if it's a Vista problem, or a problem > with my Dell computer. > Before I try calling Dell, I thought I'd see if anyone here has any ideas. > And one more thing. This happened this morning when I first turned on my > computer, before I did anything on the computer. > I booted it up and walked away to do something. When I came back I had an > error saying my slide show screen saver couldn't start. I then clicked on > my mail and realized there was no bell when my e-mails came in which meant > I had no sound so I rebooted, and got the sound back. > Could the slideshow screen saver be causing this? That's the only > connection to the problem I know about. > Sheryl |
| | Re: Keep losing my sound Thanks for the suggestions Michael. BTW, it's a desktop, and your name sounds so familiar. I use to use the newsgroups quite a bit when I first got a computer over 7 years ago but then got away from them when MSN set up groups. I think you may have helped me with some problems many years ago. Probably back when I had either win95 or 98. Were you using the newsgroups back in those days? Sheryl "Michael Solomon" <user@#notme.com> wrote in message news:%23C$0RA%23aHHA.4312@TK2MSFTNGP05.phx.gbl... > Sheryl wrote: >> I bought a new Dell Dimension E521 computer about 2 weeks ago with >> Vista Home Premium on it. >> The sound card is on board and is a Sigma Tel High Definition Audio >> Codec. (Well that's what it says on my speaker icon.) >> A few days after using the computer, I noticed I lost my sound so I >> called Dell tech and I don't think they found anything wrong. After >> being on the phone with them for quite some time, he told me to >> reboot my computer. In doing this, I had my sound back so I figured >> all was fine. A few days later, I lost my sound again but didn't call >> Dell. I just >> rebooted and got my sound back. After the second time I lost sound, I >> did receive a message that there were new sound drivers so I >> installed them and hoped this would stop this no sound from happening >> again but it didn't. I've lost sound two more times. I'm >> not sure what I'm doing or what I've done when the sound goes. I >> don't always realize it when it first happens since not everything >> you do on the computer gives you a sound but each time I lose the >> sound, all I have to do is reboot and it's back. This is not normal and I >> don't know if it's a Vista problem, or a >> problem with my Dell computer. >> Before I try calling Dell, I thought I'd see if anyone here has any >> ideas. And one more thing. This happened this morning when I first >> turned on my computer, before I did anything on the computer. >> I booted it up and walked away to do something. When I came back I >> had an error saying my slide show screen saver couldn't start. I then >> clicked on my mail and realized there was no bell when my e-mails >> came in which meant I had no sound so I rebooted, and got the sound >> back. Could the slideshow screen saver be causing this? That's the only >> connection to the problem I know about. >> Sheryl > There's almost no other way to deal with this than trial and error. Boot > the system, be sure the sound is working, then go through your normal > routine, checking the sound after each thing you do and that includes > simply opening and closing applications. You might start with the > following, think about anything you've added to the system, anything > you've installed on the laptop since you got it, any applications, open or > run them, check the sound, close them, check the sound and see if you > anything triggers it. If yes, reboot and try again with the same > application to see if it repeats, if yes, you've likely found the culprit. > After you find it, you may still want to check other things to be sure > they aren't at issue as well. > -- > Michael Solomon > |
| | Re: Keep losing my sound Yes, it does seem as if a 2 week old computer shouldn't have this problem but if I installed something that's causing the problem, I wonder if it's my problem to figure out and not Dell's. I haven't really installed too much since some of my programs don't work with Vista. Sheryl "Richard G. Harper" <rgharper@email.com> wrote in message news:e4YUrjAbHHA.960@TK2MSFTNGP03.phx.gbl... > Return your computer for repair or replacement. A two week old system > should not require this kind of user intervention. > > -- > Richard G. Harper [MVP Shell/User] rgharper@gmail.com > * NEW! Catch my blog ... http://msmvps.com/blogs/rgharper/ > * PLEASE post all messages and replies in the newsgroups > * The Website - http://rgharper.mvps.org/ > * HELP us help YOU ... http://www.dts-l.org/goodpost.htm > > > "Sheryl" <sheryltoo@snet.net> wrote in message > news:ur9QQh7aHHA.596@TK2MSFTNGP06.phx.gbl... >>I bought a new Dell Dimension E521 computer about 2 weeks ago with Vista >>Home Premium on it. >> The sound card is on board and is a Sigma Tel High Definition Audio >> Codec. (Well that's what it says on my speaker icon.) >> A few days after using the computer, I noticed I lost my sound so I >> called Dell tech and I don't think they found anything wrong. After being >> on the phone with them for quite some time, he told me to reboot my >> computer. In doing this, I had my sound back so I figured all was fine. >> A few days later, I lost my sound again but didn't call Dell. I just >> rebooted and got my sound back. After the second time I lost sound, I did >> receive a message that there were new sound drivers so I installed them >> and hoped this would stop this no sound from happening again but it >> didn't. >> I've lost sound two more times. I'm not sure what I'm doing or what I've >> done when the sound goes. I don't always realize it when it first happens >> since not everything you do on the computer gives you a sound but each >> time I lose the sound, all I have to do is reboot and it's back. >> This is not normal and I don't know if it's a Vista problem, or a problem >> with my Dell computer. >> Before I try calling Dell, I thought I'd see if anyone here has any >> ideas. >> And one more thing. This happened this morning when I first turned on my >> computer, before I did anything on the computer. >> I booted it up and walked away to do something. When I came back I had an >> error saying my slide show screen saver couldn't start. I then clicked on >> my mail and realized there was no bell when my e-mails came in which >> meant I had no sound so I rebooted, and got the sound back. >> Could the slideshow screen saver be causing this? That's the only >> connection to the problem I know about. >> Sheryl > > |
| | #6 (permalink) |
| | Re: Keep losing my sound Sheryl wrote: > Thanks for the suggestions Michael. BTW, it's a desktop, and your name > sounds so familiar. > I use to use the newsgroups quite a bit when I first got a computer > over 7 years ago but then got away from them when MSN set up groups. > I think you may have helped me with some problems many years ago. > Probably back when I had either win95 or 98. Were you using the > newsgroups back in those days? > Sheryl > "Michael Solomon" <user@#notme.com> wrote in message > news:%23C$0RA%23aHHA.4312@TK2MSFTNGP05.phx.gbl... >> Sheryl wrote: >>> I bought a new Dell Dimension E521 computer about 2 weeks ago with >>> Vista Home Premium on it. >>> The sound card is on board and is a Sigma Tel High Definition Audio >>> Codec. (Well that's what it says on my speaker icon.) >>> A few days after using the computer, I noticed I lost my sound so I >>> called Dell tech and I don't think they found anything wrong. After >>> being on the phone with them for quite some time, he told me to >>> reboot my computer. In doing this, I had my sound back so I figured >>> all was fine. A few days later, I lost my sound again but didn't >>> call Dell. I just >>> rebooted and got my sound back. After the second time I lost sound, >>> I did receive a message that there were new sound drivers so I >>> installed them and hoped this would stop this no sound from >>> happening again but it didn't. I've lost sound two more times. I'm >>> not sure what I'm doing or what I've done when the sound goes. I >>> don't always realize it when it first happens since not everything >>> you do on the computer gives you a sound but each time I lose the >>> sound, all I have to do is reboot and it's back. This is not normal >>> and I don't know if it's a Vista problem, or a >>> problem with my Dell computer. >>> Before I try calling Dell, I thought I'd see if anyone here has any >>> ideas. And one more thing. This happened this morning when I first >>> turned on my computer, before I did anything on the computer. >>> I booted it up and walked away to do something. When I came back I >>> had an error saying my slide show screen saver couldn't start. I >>> then clicked on my mail and realized there was no bell when my >>> e-mails came in which meant I had no sound so I rebooted, and got the >>> sound >>> back. Could the slideshow screen saver be causing this? That's the >>> only connection to the problem I know about. >>> Sheryl >> There's almost no other way to deal with this than trial and error. Boot >> the system, be sure the sound is working, then go through your >> normal routine, checking the sound after each thing you do and that >> includes simply opening and closing applications. You might start >> with the following, think about anything you've added to the system, >> anything you've installed on the laptop since you got it, any >> applications, open or run them, check the sound, close them, check >> the sound and see if you anything triggers it. If yes, reboot and >> try again with the same application to see if it repeats, if yes, >> you've likely found the culprit. After you find it, you may still >> want to check other things to be sure they aren't at issue as well. >> -- >> Michael Solomon You're welcome, Sheryl and your time frame and memory are correct. I used to spend a lot of time on a couple of the old MSN newsgroups, later I was in the MSN Members Helping Members program, then Assistant Forum Manager in the IE and Safe Computing forums and for several years I was an MS-MVP in the Shell/User group. While Richard is certainly correct that you shouldn't have this problem on a 2 week old computer your instincts about it possibly being related to something you have installed are good. While you apparantly haven't installed much, you might still run the test I suggested with what you have installed. Remove an application, then test and see if you have the problem and continue to test on whatever other applications you've installed until you've either resolved the issue or removed all such additional apps. I make this suggestion because if it is something you've installed and you install it again on a replacement PC, you might once again trigger the issue. -- Michael Solomon |
| | #7 (permalink) |
| | Re: Keep losing my sound Thanks again Michael. And it's nice to see you again. I do remember you being very helpful in the past. There were a lot of helpful people from those old newsgroups that taught me an awful lot about computers. One person even taught me how to reformat my computer. I think about her a lot and wonder if she's still around. Her name was Dorothy. Ring any bells? I'm finding out there's still a lot of helpful people around, but they're mostly strangers to me. I do appreciate the help everyone gives to people like me who don't always know what they're doing or why their computer isn't working right. Thanks again. Sheryl > You're welcome, Sheryl and your time frame and memory are correct. I used > to spend a lot of time on a couple of the old MSN newsgroups, later I was > in the MSN Members Helping Members program, then Assistant Forum Manager > in the IE and Safe Computing forums and for several years I was an MS-MVP > in the Shell/User group. > > While Richard is certainly correct that you shouldn't have this problem on > a 2 week old computer your instincts about it possibly being related to > something you have installed are good. While you apparantly haven't > installed much, you might still run the test I suggested with what you > have installed. Remove an application, then test and see if you have the > problem and continue to test on whatever other applications you've > installed until you've either resolved the issue or removed all such > additional apps. > > I make this suggestion because if it is something you've installed and you > install it again on a replacement PC, you might once again trigger the > issue. > > -- > Michael Solomon > |
| | #8 (permalink) |
| | Re: Keep losing my sound Sheryl wrote: > Thanks again Michael. > And it's nice to see you again. I do remember you being very helpful > in the past. > There were a lot of helpful people from those old newsgroups that > taught me an awful lot about computers. > One person even taught me how to reformat my computer. I think about > her a lot and wonder if she's still around. > Her name was Dorothy. Ring any bells? > I'm finding out there's still a lot of helpful people around, but > they're mostly strangers to me. > I do appreciate the help everyone gives to people like me who don't > always know what they're doing or why their computer isn't working > right. Thanks again. > Sheryl >> -- Well, you've certainly brought back some memories and yes, I remember Dorothy. The newsgroup was MSN Memberservices and while I was able to find references to it in a Google search, upon clicking the link, the archive came up empty. I guess it was just too long ago!:-) I do from time to time, still run into some of those people and some others still get together in a private group. You're welcome, Sheryl, nice to see you again as well. Glad I could help. -- Michael Solomon |
| | #9 (permalink) |
| | Re: Keep losing my sound I guess that was a lifetime ago. I miss some of those helpful people. Sheryl > Well, you've certainly brought back some memories and yes, I remember > Dorothy. The newsgroup was MSN Memberservices and while I was able to > find references to it in a Google search, upon clicking the link, the > archive came up empty. I guess it was just too long ago!:-) > > I do from time to time, still run into some of those people and some > others still get together in a private group. > > You're welcome, Sheryl, nice to see you again as well. > > Glad I could help. > > -- > Michael Solomon > |
| | #10 (permalink) |
| | Re: Keep losing my sound Sheryl wrote: > Yes, it does seem as if a 2 week old computer shouldn't have this > problem but if I installed something that's causing the problem, I > wonder if it's my problem to figure out and not Dell's... Well, both Dell and MS would like their customers to think that way. If you don't make a fuss now you may lose your chance to return the machine later on, and no one at Dell or MS will be motivated to find or fix bugs. Keep the pressure on, I say. |
| Losing the sound icon in my system tray | Vista performance & maintenance | |||
| Losing sound comes back after reboot | Sound & Audio | |||
| losing sound on the right laptop speaker | Sound & Audio | |||
| Losing Sound and TV at start up | Vista hardware & devices | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
