| | Dual Monitor Issue I am running dual monitors, and having a problem w/ the arrangment of the monitors. In Display Settings, I arrange Monitor 1 above Monitor 2. The settings take effect w/o any problems. However, if I lock the computer and then unlock it the settings go back to the default arrangements of the monitors being side-by-side. So is there a way to keep it from doing this or is there a way to change the default arrangement from side-by-side to top and bottom? Thank you in advance for you help! |
| | Re: Dual Monitor Issue "Hutch" <Hutch@discussions.microsoft.com> wrote in message news:CA57998A-FC24-4005-B33E-978F5502237F@microsoft.com... >I am running dual monitors, and having a problem w/ the arrangment of the > monitors. In Display Settings, I arrange Monitor 1 above Monitor 2. The > settings take effect w/o any problems. However, if I lock the computer > and > then unlock it the settings go back to the default arrangements of the > monitors being side-by-side. > > So is there a way to keep it from doing this or is there a way to change > the > default arrangement from side-by-side to top and bottom? > > Thank you in advance for you help! No answer but curious. Do you actually have your 2nd monitor physically over your main monitor. |
| | Re: Dual Monitor Issue Yes, I do. I am using a laptop with a screen above it. "DanR" wrote: > > "Hutch" <Hutch@discussions.microsoft.com> wrote in message > news:CA57998A-FC24-4005-B33E-978F5502237F@microsoft.com... > >I am running dual monitors, and having a problem w/ the arrangment of the > > monitors. In Display Settings, I arrange Monitor 1 above Monitor 2. The > > settings take effect w/o any problems. However, if I lock the computer > > and > > then unlock it the settings go back to the default arrangements of the > > monitors being side-by-side. > > > > So is there a way to keep it from doing this or is there a way to change > > the > > default arrangement from side-by-side to top and bottom? > > > > Thank you in advance for you help! > > No answer but curious. Do you actually have your 2nd monitor physically over > your main monitor. > > |
| | Re: Dual Monitor Issue Sounds like a genuine bug to me. Does anyone know how to report bugs to the Vista team? Thack |
| | Re: Dual Monitor Issue The representation is there to show two monitors, which would generally be side by side.. the fact that you have one above the other is immaterial.. you will also notice that there is no way to have one facing the other way, even though that may be the way yours are physically aligned.. ![]() "Hutch" <Hutch@discussions.microsoft.com> wrote in message news:B721FDF5-C236-47A7-9399-AFFB05367AAD@microsoft.com... > Yes, I do. I am using a laptop with a screen above it. > > "DanR" wrote: > >> >> "Hutch" <Hutch@discussions.microsoft.com> wrote in message >> news:CA57998A-FC24-4005-B33E-978F5502237F@microsoft.com... >> >I am running dual monitors, and having a problem w/ the arrangment of >> >the >> > monitors. In Display Settings, I arrange Monitor 1 above Monitor 2. >> > The >> > settings take effect w/o any problems. However, if I lock the computer >> > and >> > then unlock it the settings go back to the default arrangements of the >> > monitors being side-by-side. >> > >> > So is there a way to keep it from doing this or is there a way to >> > change >> > the >> > default arrangement from side-by-side to top and bottom? >> > >> > Thank you in advance for you help! >> >> No answer but curious. Do you actually have your 2nd monitor physically >> over >> your main monitor. >> >> -- Mike Hall MS MVP Windows Shell/User http://msmvps.com/blogs/mikehall/ |
| | #6 (permalink) |
| | Re: Dual Monitor Issue With respect, Mike, you obviously don't know anything about this. It is NOT merely a representation of two monitors. When you move the little monitor icons around it adjusts the relative co-ordinates of the two screens in the OS. Placing one above the other - or below it - or to either side, moves the LOGICAL position of the screens in Vista, which affects the desktop size and shape. And yes, Vista should definitely remember where the relative positions of the screens are. Mike, as an MS MVP you really shouldn't be making pronouncements in areas you don't have expertise. It reflects badly on the rest of the MVP community. Steve |
| | #7 (permalink) |
| | Re: Dual Monitor Issue "Steve Thackery" <thack@nowhere.net> wrote in message news:%23PuSzvHbHHA.4000@TK2MSFTNGP02.phx.gbl... > With respect, Mike, you obviously don't know anything about this. It is > NOT merely a representation of two monitors. When you move the little > monitor icons around it adjusts the relative co-ordinates of the two > screens in the OS. > > Placing one above the other - or below it - or to either side, moves the > LOGICAL position of the screens in Vista, which affects the desktop size > and shape. > > And yes, Vista should definitely remember where the relative positions of > the screens are. > > Mike, as an MS MVP you really shouldn't be making pronouncements in areas > you don't have expertise. It reflects badly on the rest of the MVP > community. > > Steve > I set my 2 monitors up this way just to see what would happen. The one thing I noticed is that the mouse will track up and down between the monitors instead of left to right. |
| | #8 (permalink) |
| | Re: Dual Monitor Issue I've had the same issue getting my monitors to remain arranged backwards to the default. I have monitor 2 as my secondary extended desktop but since it's widescreen i had to physically put it where i had space available. So i set it up to scroll across from the left side of my main monitor to the WS display. Problem, I lock the computer and on resume it goes back to scrolling from the right. Physically it looks like this: Monitor 2 - Monitor 1 I had it fixed once...then it reverted. Any ideas? "Steve Thackery" wrote: > Sounds like a genuine bug to me. > > Does anyone know how to report bugs to the Vista team? > > Thack > > > |
| | #9 (permalink) |
| | Re: Dual Monitor Issue Sorry, no. That's why I said it's almost certainly a bug. You can definitely do this in XP, and it remembers the setting perfectly. Steve |
| | #10 (permalink) |
| | Re: Dual Monitor Issue > I set my 2 monitors up this way just to see what would happen. The one > thing I noticed is that the mouse will track up and down between the > monitors instead of left to right. That's right. You can even use monitors with different resolutions, and in that case can choose whether to align the left edges or the right edges (or the tops and bottoms if the monitors are in the more usual side-by-side position). As Velamint says, you can even drag the secondary monitor to the wrong side of the primary, so the mouse behaviour seems completely confusing - a good trick to play if someone in the office has left their machine unlocked. Steve |
| dual monitor maximize issue | General Discussion | |||
| laptop docking - dual monitor issue | Vista General | |||
| Dual use of LCD monitor | Vista hardware & devices | |||
| Monitor issue or full instal issue | Vista installation & setup | |||
| Sceen Saver Issue with Dual Monitor | Vista General | |||
