| | Vertical Scrolling Sensitivity Varies Dramatically within Same Application Within the same Microsoft applications and even Vista itself, wheel scrolling vertical sensitivity varies widely. e.g.: Microsoft Money Normal scrolling within reports, but to merely move the check register requires 5-10 wheel spins (more with Accelerated Scrolling disabled). The latest IntelliPoint driver (6.1) for Microsoft Wireless Laser Mouse 6000 is installed. No other mouse or mouse drivers have ever been present on this clean install other than what is already within Vista. Vertical scrolling seems to function normally after uninstalling IntelliPoint, but since there is no other way to monitor battery level, among other features, operating without IntelliPoint is a nonstarter. At this point I would seriously consider replacing the mouse if I knew I would not encounter the same problem. So, is this a driver problem that will eventually be rectified, or do I contact Microsoft only to hear "Reinstall Vista"? Known Affected Applications (so far): Microsoft Money 2007 Microsoft Office 2007 Vista Control Panel Applets such as System Environment: Vista Ultimate Microsoft Wireless Laser Mouse 6000 IntelliPoint 6.1 Microsoft Natural Ergonomic Keyboard 4000 IntelliType Pro 6.1 |
| | RE: Vertical Scrolling Sensitivity Varies Dramatically within Same App There are many posts re Intellipoint problems for XP and Vista. I have screen redraw issues on 2 programs and the only solution is to end the ipoint.exe process. "Brent" wrote: > Within the same Microsoft applications and even Vista itself, wheel > scrolling vertical sensitivity varies widely. > > e.g.: > Microsoft Money > Normal scrolling within reports, but to merely move the check register > requires 5-10 wheel spins (more with Accelerated Scrolling disabled). > > The latest IntelliPoint driver (6.1) for Microsoft Wireless Laser Mouse > 6000 is installed. No other mouse or mouse drivers have ever been > present on this clean install other than what is already within Vista. > > Vertical scrolling seems to function normally after uninstalling > IntelliPoint, but since there is no other way to monitor battery level, > among other features, operating without IntelliPoint is a nonstarter. > > At this point I would seriously consider replacing the mouse if I knew I > would not encounter the same problem. So, is this a driver problem that > will eventually be rectified, or do I contact Microsoft only to hear > "Reinstall Vista"? > > Known Affected Applications (so far): > Microsoft Money 2007 > Microsoft Office 2007 > Vista Control Panel Applets such as System > > Environment: > Vista Ultimate > Microsoft Wireless Laser Mouse 6000 > IntelliPoint 6.1 > Microsoft Natural Ergonomic Keyboard 4000 > IntelliType Pro 6.1 > > |
| | Re: Vertical Scrolling Sensitivity Varies Dramatically within Same Application Here I thought I was crazy - but I'm not the only one seeing this. I also have Vista and a MS Mouse (Wireless Notebook Optical 4000). My mouse exhibited this behavior *before* installing the Intellipoint driver. I installed Intellipoint hoping it would fix the issue. Alas, no luck. I get slow vertical scrolling in OneNote, and MS Access so far that I have noticed. Scrolling in IE, Word, Excel all work as expected. Unfortunately I have no solution for you, but I can at least confirm that it is an issue. --David. On Mar 23, 3:39 am, "Brent" <HarvestT...@Spammers.Net> wrote: > Within the same Microsoft applications and evenVistaitself,wheelscrollingverticalsensitivity varies widely. > > e.g.: > Microsoft Money > Normalscrollingwithin reports, but to merely move the check register > requires 5-10wheelspins (more with AcceleratedScrollingdisabled). > > The latest IntelliPoint driver (6.1) for Microsoft Wireless LaserMouse > 6000 is installed. No othermouseormousedrivers have ever been > present on this clean install other than what is already withinVista. > > Verticalscrollingseems to function normally after uninstalling > IntelliPoint, but since there is no other way to monitor battery level, > among other features, operating without IntelliPoint is a nonstarter. > > At this point I would seriously consider replacing themouseif I knew I > would not encounter the same problem. So, is this a driver problem that > will eventually be rectified, or do I contact Microsoft only to hear > "ReinstallVista"? > > Known Affected Applications (so far): > Microsoft Money 2007 > Microsoft Office 2007VistaControl Panel Applets such as System > > Environment:VistaUltimate > Microsoft Wireless LaserMouse6000 > IntelliPoint 6.1 > Microsoft Natural Ergonomic Keyboard 4000 > IntelliType Pro 6.1 |
| | Re: Vertical Scrolling Sensitivity Varies Dramatically within Same It's a known problem. Some tilt-wheel mice with Intellipoint 6.1 produce Z axis (scroll wheel) values that aren't what various applications are expecting. Apps I've seen affected personally are iTunes and OpenOffice. Many applications expect Z to be +/-120 per wheel 'step'. Some tilt-wheel mice produce variable values ranging from +/-30 when the wheel is being slowly rotated up to +/-1000 for a fast spin. The actual values vary by mouse and whether or not Intellipoint is filtering the input. In a nutshell: If the wheel is spinning too slow, the application ignores it. Then it scrolls way too much when wheel is spun faster. If these apps scroll properly before you install IPoint 6.1, the problem is IPoint modifying the scroll values: Set your mouse model to something without a tilt wheel (but with the same number of buttons!). If you have scroll problems even without Intellipoint, your mouse itself is sending variable values (like my Wireless Laser 6000...) Either an update to Intellipoint or the affected app will be required. "dkiernan@kccomputersales.com" wrote: > Here I thought I was crazy - but I'm not the only one seeing this. > > |
| Why Vista's networking speed varies? | Vista networking & sharing | |||
| Vertical scrolling problems with mouse | Vista hardware & devices | |||
| Computer dramatically slow with Vista | Vista account administration | |||
| Vertical scrolling...jumps rather than smooth scrolling - Excel 20 | Vista hardware & devices | |||
| Bug? Drag-drop quoting varies and causes behavior aberrations | PowerShell | |||
