Vista Tutorial - Vista Modem Problem -- Much Too Slow
Old 03-27-2007   #1 (permalink)
Kevin
Guest
I just bought a new Dell computer with Vista pre-installed. Previously I
used AOL and used the pre-installed AOL here as well, but the modem is
dog-slow. It says it is connecting at 24k or faster, but it takes 30 minutes
to load a page. And that's if I don't get the AOL timeout errors, which
occur most of the time.
Thinking it was AOL, I tried to register with another dial-up ISP -- and
their pages took 30 minutes to load as well. I could not even register
because their pages would not load.
I desinstalled the modem driver and reinstalled it. I checked for an
updated driver but don't see one -- this one is dated 2004.
What else can I check? Broadband is not an option. Thanks in advance.
Old 03-27-2007   #2 (permalink)
Carlos
Guest
RE: Vista Modem Problem -- Much Too Slow
Kevin:
Please be more specific.
What modem are you using (make, model)?
Is it internal or external?
Your phone line might also be noisy, preventing higher connection speeds.
Carlos
Very slow modem - Please Help Vista print fax & scan
SLOW Internet on Vista via ADSL Modem. Vista networking & sharing
Slow Cable Modem/Linksys router connect Vista networking & sharing
problem of installing of a usb modem on vista Vista General
