Vista - How does copy work?
Old 03-27-2007   #1 (permalink)
Farbuncle
How does copy work?
Vista Home Premium. How do I copy a file from one device to another?
Click and drag actually moves the file. I tried copy and paste and that
worked from C: to A" drive. Is that how its done or is there a copy command?
Thanks
Old 03-27-2007   #2 (permalink)
dev
Re: How does copy work?
Right-click/DRAG, then let go of the mouse. You should be presented
with choices.
Old 03-27-2007   #3 (permalink)
Michael Solomon
> that worked from C: to A" drive. Is that how its done or is there a
> copy command?
> Thanks
Have you tried right click dragging, that brings up a menu when you release
at the destination and asks if you wish to move, copy, etc.
Michael Solomon
Old 03-28-2007   #4 (permalink)
Farbuncle
Thanks, works a treat. All the wonderous things you can do if you only know
how.
> > copy command?
> > Thanks
> Michael Solomon
Old 03-28-2007   #5 (permalink)
Michael Solomon
> only know how.
>> release at the destination and asks if you wish to move, copy, etc.
>> Michael Solomon
You're welcome.
Michael Solomon
Old 03-29-2007   #6 (permalink)
Mick
RE: How does copy work?
If you are in Documents in C, and want to send to A, right-click on what you
want to send to A, and in the menu that comes up, run your cursor over "send
to", and you have your choice from the next menu where you want to seed it
to, email, CD, A, Memory stick, etc.
Too easy!
Mick in Australia
> Thanks
Contacts copy and paste does not work Live Mail
copy and paste do not work General Discussion
Copy & Paste doesn't work on first try Vista General
Copy/paste doesn't work Vista General
