Vista - My Areo Glass on the Taskbar and i need yur help!!
Old 03-28-2007   #1 (permalink)
Papz
Hello Alll
i have lost my areo glass look on the taskbar on windows vista and i
got Vista Home Premium, and i dont know how to get it back.
and the wired thing is i used to have it after i upgraded to vista
my prevous os was xp Home Edition. And other wired thing is the guest
account has the areo glass look on the taskbar, but not mine account.
How should i get it back?
Old 03-28-2007   #2 (permalink)
dingo
Re: My Areo Glass on the Taskbar and i need yur help!!
side click on your screen,click (personalize),then youll get a menu
screen,click on (windows Color and Appearance)IN THE APPEARANCE SCREEN-click
on windos Aero,then click Apply.done
"Papz" <Papz@discussions.microsoft.com> wrote in message
news:F0AD30BF-75F6-4FCF-81AF-38BBFF9F30AF@microsoft.com...
> Hello Alll
> i
Old 03-31-2007   #3 (permalink)
Justin Shupp
If it is only on the taskbar, then there is a good chance you have selected
something like the Itunes tool bar to be displayed on the taskbar (right
click on the taskbar, select toolbars, and see what is selected). Certain
tool bars force the taskbar to become solid again, instead of transparent.
Not sure if that is it, but it is a good place to start looking.
Justin
> Hello Alll
> i
Old 05-24-2007   #4 (permalink)
This is so annoying.....
RE: My Areo Glass on the Taskbar and i need yur help!!
Any time you have a window maximized, the taskbar will become opaque (not
transparent, as it normally is). This also happens if, like me, you have the
iTunes toolbar on your taskbar, even if iTunes is not open at all. My guess
is that it will happen with any toolbar that is not meant to be transparent.
Another thing that might help is if you go to the Personalization window
and click Window Color and Appearance, you should see a color intensity
slider under all of the colors. Make sure that is not all the way to the
right or nothing (including the windows, start menu, taskbar, etc.) will be
transparent.
Hope one of those helps.
"Papz" wrote:
> Hello Alll
How to fix areo probelm General Discussion
Aero Glass effects on Taskbar and Start Menu... Vista General
Areo Glass and Windows Sever 2003 Domain user Accounts Vista General
Taskbar glass Vista General
