Vista Tutorial - stuck shift key
Old 03-28-2007   #1 (permalink)
MR
Guest
stuck shift key
The left-shift and/or left-control keys always "stick" when pressed in
conjunction with the Home, End, Delete, PageUp, PageDown and arrow keys.
That means that any key press or mouse click will behave as if the shift/and
or the control key are pressed until i press the left-shift or left-control
again
I saw KB article 266140 ( http://support.microsoft.com/kb/266140) where this
behavior is described but the two causes listed there are not relevant in
this case.
Is anyone familiar with this issue? is there a solution?
I am using a Microsoft Wireless Comfort Keyboard 1.0A with Vista Business
Edition
I installed the Intellitype software, version 6.1
I upgraded from XP where I did not have this problem
thanks
m
Old 04-01-2007   #2 (permalink)
Zoom
Guest
Re: stuck shift key
i have the same problem. does anyone have a solution for this?
"MR" <comconix@newsgroup.nospam> wrote in message
news:478940C2-78F6-47DA-A77C-C43B78F855FA@microsoft.com...
> shift/and or the control key are pressed until i press the left-shift or
> left-control again
> this behavior is described but the two causes listed there are not
> relevant in this case.
> Edition
> thanks
> m
Old 04-01-2007   #3 (permalink)
Cal Bear '66
Guest
Re: stuck shift key
Have you checked your keyboard setting in Accessories>Ease of Access Center?
"Zoom" <moshe.raab @ [no-spam] zoomix.com> wrote in message news:e$5kG2DdHHA.2316@TK2MSFTNGP04.phx.gbl...
>> left-control again
>> Edition
>> thanks
>> m
Old 04-01-2007   #4 (permalink)
MR
Guest
Re: stuck shift key
there is nothing checked in that dialog box
"Cal Bear '66" <xxx@xxx.org> wrote in message
news:580D5F4D-C96E-407B-92AE-4E5ABCF61AB5@microsoft.com...
>> left-control again
>> Edition
>> thanks
>> m
Old 02-29-2008   #5 (permalink)
logicadi
Guest
Re: stuck shift key
Hello,
I had the same problem and I found a possible solution.
I tried it and I didn't face again the same problem until now (the last
3-4 days).
The problem seems to be the wireless mouse and the microsoft "driver"
intellipoint.
I uninstall the software and the problem seems to be solved.
See also these links:
'Ctrl key stuck w/ Intellipoint 5.2'
(http://hardware.mcse.ms/message60168.html)
'Microsoft IntelliPoint Replacement - Customize your Microsoft Mouse
buttons' (http://mousehook.de/)
I hope that it's the same problem and that this is the solution for
you, because I can understand the mad situation of the stuck ctrl key.
adi
logicadi
Posted via http://www.vistaheads.com
Question about bit shift .NET General
Need For Speed Shift Gaming
I know I can ctrl-shift-a, but...... Live Mail
SHIFT KEY OUT OF CONTROL Vista General
Shift+Tab does not work Vista General
