| | Keyboard does not work! Please help! Right now, I'm using the On-Screen Keyboard so I'll make things short. 1. Top keys (Sleep, internet, mail, etc.) work fine. 2. The rest don't work. 3. It's not a connection problem, I've checked. 4. Reboot fails to fix the problem. 5. Windows Vista 32-bit Home Premium. 6. Mouse works fine. 7. Keyboard's Num Lock LED is on. 8. LED status doesn't change via keyboard nor On-Screen Keyboard 9. Was fine until sudden crash, BlueScreen, self-rebooted. PLEASE help! Thanks, Jack |
| | Re: Keyboard does not work! Please help! sounds like a driver problem...go download the latest driver from your key board brand site on the net. "Noodlepowa" <Noodlepowa@discussions.microsoft.com> wrote in message news:955CB494-C656-41E7-A635-04A59BD61696@microsoft.com... > Right now, I'm using the On-Screen Keyboard so I'll make things short. > > 1. Top keys (Sleep, internet, mail, etc.) work fine. > 2. The rest don't work. > 3. It's not a connection problem, I've checked. > 4. Reboot fails to fix the problem. > 5. Windows Vista 32-bit Home Premium. > 6. Mouse works fine. > 7. Keyboard's Num Lock LED is on. > 8. LED status doesn't change via keyboard nor On-Screen Keyboard > 9. Was fine until sudden crash, BlueScreen, self-rebooted. > > PLEASE help! > > > Thanks, > Jack |
| | Re: Keyboard does not work! Please help! Does the keyboard work to get into the BIOS settings? If not, it's dead. |
| | Re: Keyboard does not work! Please help! My computer says that I have the latest keyboard driver installed. What is BIOS? Something about input/output systems? Sorry if that was kind of "newbish"... |
| | Re: Keyboard does not work! Please help! Noodlepowa wrote: > My computer says that I have the latest keyboard driver installed. > > What is BIOS?... Most computers print a screen during bootup that asks you to hit the DEL (delete) key to enter the BIOS setup facility. You really should know and understand at least the basic functions that your computer's BIOS does for you. Not everything, mind you, but usually the BIOS setup will separate basic functions from advanced functions -- and even I don't mess with the advanced settings, even after years of practice. |
| | #6 (permalink) |
| | Re: Keyboard does not work! Please help! "Don" wrote: > Noodlepowa wrote: > > My computer says that I have the latest keyboard driver installed. > > > > What is BIOS?... > > Most computers print a screen during bootup that asks you to hit the > DEL (delete) key to enter the BIOS setup facility. You really should > know and understand at least the basic functions that your computer's > BIOS does for you. Not everything, mind you, but usually the BIOS > setup will separate basic functions from advanced functions -- and > even I don't mess with the advanced settings, even after years of > practice. > > > Thank you all for your replies! I really appreciate it. Anyway, I got so frustrated with this that I decided to reformat my entire computer. Now it works! I don't know what was wrong, but all I know is that the keyboard wouldn't function correctly after a sudden crash and reboot, and the mouse would still work. Again, thank you all for your replies. Thanks, Jack |
| Keyboard doesn't work | Vista hardware & devices | |||
| ps2 keyboard won't work | Vista hardware & devices | |||
| RE: ps2 keyboard won't work | Vista hardware & devices | |||
