Vista - hot to change mouse to single click instead of double click to ope
Old 06-14-2006   #1 (permalink)
joseph bell
how can I change from double clicking to single click. In XP you can go to
folder options and make the change, here I can't find that option in Vista.
Vista is exciting
ajabell
Old 06-14-2006   #2 (permalink)
Chris S
RE: hot to change mouse to single click instead of double click to ope
Open up the control panel and go to folder options.
AMD-FX-60
2gb OCZ Plat. memory
ATI 1800 AIW
2x74gb Raptors in RAID-0
2x400gb WD HDD in RAID-1
Epox Nvidia-4 Ultra M/B
Senior Member Overclockers.com
> Vista is exciting
> ajabell
Set Single Click for Mouse - How Vista General
How do I change the mouse click to just one click Vista General
My mouse double clicks frequently when I single click it Vista hardware & devices
Single Click Instead Of Double Click Vista General
mouse single click Vista hardware & devices
