| | Sound trashed Running Vista Business edition, motherboard D945PSN with PentiumD 3GHz, upgraded from XP Pro. The motherboard has built-in sound. The previously excellent 6 speaker sound has turned to rubbish. The sound is distorted and only 3 speakers work. Can anyone help? TIA Andrew |
| | Re: Sound trashed /Andrew/ said: > Running Vista Business edition, motherboard D945PSN with PentiumD 3GHz, > upgraded from XP Pro. The motherboard has built-in sound. > > The previously excellent 6 speaker sound has turned to rubbish. The sound is > distorted and only 3 speakers work. Can anyone help? Have you checked the MB manufacturer's WEBsite for Vista drivers? Sound handling in this O/S is considerably changed from its predecessors. |
| | Re: Sound trashed You need a Vista supported sound card driver file, see: http://downloadfinder.intel.com/scri...%2032&lang=eng -- Best of Luck, Rick Rogers, aka "Nutcase" - Microsoft MVP http://mvp.support.microsoft.com/ Windows help - www.rickrogers.org "Andrew" <noway@forgetit.com> wrote in message news:23E9F8E8-5186-4FD8-A7D4-4F0C6768B525@microsoft.com... > Running Vista Business edition, motherboard D945PSN with PentiumD 3GHz, > upgraded from XP Pro. The motherboard has built-in sound. > > The previously excellent 6 speaker sound has turned to rubbish. The sound > is distorted and only 3 speakers work. Can anyone help? > > TIA > Andrew |
| | RE: Sound trashed If all the other advice fails try another sound card. I found a cheap one that WORKS in Vista Home Premium! "Cobra" is the name http://www.aopen.com is the manifacturers website. "Andrew" wrote: > Running Vista Business edition, motherboard D945PSN with PentiumD 3GHz, > upgraded from XP Pro. The motherboard has built-in sound. > > The previously excellent 6 speaker sound has turned to rubbish. The sound is > distorted and only 3 speakers work. Can anyone help? > > TIA > Andrew > |
| | Re: Sound trashed Nice try but the installer says it's not the correct driver for this system and exits. "Rick Rogers" <rick@mvps.org> wrote in message news:ub9PvrddHHA.3408@TK2MSFTNGP03.phx.gbl... > You need a Vista supported sound card driver file, see: > http://downloadfinder.intel.com/scri...%2032&lang=eng > > -- > Best of Luck, > > Rick Rogers, aka "Nutcase" - Microsoft MVP > http://mvp.support.microsoft.com/ > Windows help - www.rickrogers.org > > "Andrew" <noway@forgetit.com> wrote in message > news:23E9F8E8-5186-4FD8-A7D4-4F0C6768B525@microsoft.com... >> Running Vista Business edition, motherboard D945PSN with PentiumD 3GHz, >> upgraded from XP Pro. The motherboard has built-in sound. >> >> The previously excellent 6 speaker sound has turned to rubbish. The sound >> is distorted and only 3 speakers work. Can anyone help? >> >> TIA >> Andrew > |
| NTFS Partition is trashed, could somebody tell me how to fix it? | General Discussion | |||
| SP1 trashed my wireless adapter | Vista General | |||
| my taskbar in vista is TRASHED.... | Vista General | |||
| Trashed Personal subolders (Help please) | Vista General | |||
| Trashed my Nvidia Driver | Vista installation & setup | |||
