| | display on monitor question Um, I turned on my computer and the desktop/displays were rotated 90 degrees. Which means the left side of the monitor now the bottom. I hope that makes sense.. if it doesn't, imagine needing turning your monitor on its side in order to read and click everything properly. ack, I hope I put this in the right place.. |
| | RE: display on monitor question never mind i figured it out. oops. "sleepy" wrote: > Um, I turned on my computer and the desktop/displays were rotated 90 degrees. > > Which means the left side of the monitor now the bottom. > > I hope that makes sense.. if it doesn't, imagine needing turning your > monitor on its side in order to read and click everything properly. > > ack, I hope I put this in the right place.. |
| Re: No monitor display | Vista General | |||
| No monitor display | Vista performance & maintenance | |||
| No display on monitor | Vista music pictures video | |||
| Display on second monitor | Vista hardware & devices | |||
| Help, monitor won't display | Vista hardware & devices | |||
