Vista - Problem with running Netgear WG311T device
Old 04-05-2007   #1 (permalink)
Luke
Hi I've just installed Netgear WG311T wireless network card onto my new
system, which is running windows vista. I've also downloaded the lastest
window vista compatible driver from the manufacturer website. However I
still cant get the device to work properley. The following error message
keeps popping up:
"This device is not working properly because Windows cannot load the drivers
required for this device. (Code 31)
Click 'Check for solutions' to send data about this device to Microsoft and
to see if there is a solution available."
Old 04-05-2007   #2 (permalink)
Natéag
Re: Problem with running Netgear WG311T device
It runs perfectly on my computer with
those drivers. Have you tried to install them
from the Device *Hardware?) Manager
pointing to the folder where your drivers are located
when asked.
"Luke" <Luke@discussions.microsoft.com> a écrit dans le message de
news:809FE764-BC7D-42A3-991A-5A9526171D15@microsoft.com...
> keeps popping up:
> drivers
> and
Old 04-06-2007   #3 (permalink)
Jeff
RE: Problem with running Netgear WG311T device
> keeps popping up:
Old 04-06-2007   #4 (permalink)
Jeff
I haven't been able to get the current drivers to work either, but I have
been running with the drivers on the Netgear install CD just fine.
> keeps popping up:
Old 10-21-2007   #5 (permalink)
Vista Ultimate x64 Service Pack I
same deal any ideas??
Old 10-22-2007   #6 (permalink)
cqui3
"mathews2010" <mathews2010.2yto31@xxxxxx-mx.forums.net> a écrit dans le message
de news:mathews2010.2yto31@xxxxxx-mx.forums.net...
> mathews2010
> - ::Intel Quad Core (Q6600)::
> - ::216BW Samsung::
> - ::Nvidia 8400 GS::
> - ::320 GB Seagate HDD::
> - ::2 GB G.Skill (DDR 2 800) ::
> - ::ASUS P5K LGA 775 Intel P35 ATX Intel Motherboard...::
> - ::Vista x64::
On a trouvé. un certain temps un pilote WG311T compatible avec Vista.
Depuis il faut télécharger les pilotes Atheros (c'est le nom du contrôleur
monté
sur cette carte). Fonctionne très bien.
Netgear Router & Adapter Problem Network & Sharing
Netgear wg311v3 on a dell system This device cannot start. (Code Vista hardware & devices
vista netgear wireless problem Vista General
Netgear wg311T works ! Vista hardware & devices
Netgear problem Vista General
