| Guest | Monitor resolution i have a NEC MultiSync LCD195WVXM monitor, and window XP.... but then, the system does not support the resolution of 1440 X 900... someone told me that it works if i download DirectX 9C....but..i don't think it does.. what can i do?.. thank you |
| Guest | Re: Monitor resolution On Fri, 6 Apr 2007 12:32:00 -0700, 1440 x 900 Resolution Problem <1440 x 900 Resolution Problem@discussions.microsoft.com> wrote: >i have a NEC MultiSync LCD195WVXM monitor, and window XP.... >but then, the system does not support the resolution of 1440 X 900... >someone told me that it works if i download DirectX 9C....but..i don't think >it does.. >what can i do?.. thank you If after checking that you have the latest drivers for the Video card you have. Buy a new video card that supports that resolution. Direct x only makes use of what you have configured. |
| Guest | Re: Monitor resolution There were some problems with NVIDIA Vista drivers supporting 1440x900. However from what I have read the latest 101.41 Beta drivers have resolved the problem. "Steve Urbach" <dragonsclaw@NOTmindspring.com> wrote in message news:6n8d13psobeh75mtplrcs64v1iaph7cf70@4ax.com... > On Fri, 6 Apr 2007 12:32:00 -0700, 1440 x 900 Resolution Problem <1440 > x 900 Resolution Problem@discussions.microsoft.com> wrote: > >>i have a NEC MultiSync LCD195WVXM monitor, and window XP.... >>but then, the system does not support the resolution of 1440 X 900... >>someone told me that it works if i download DirectX 9C....but..i don't >>think >>it does.. >>what can i do?.. thank you > If after checking that you have the latest drivers for the Video card > you have. Buy a new video card that supports that resolution. > Direct x only makes use of what you have configured. |
| Monitor Resolution | Graphic cards | |||
| Monitor Resolution Problem | Vista General | |||
| Monitor resolution | Vista General | |||
| Monitor resolution | Vista hardware & devices | |||
