Vista - Sound issues with left channel
Old 04-10-2007   #1 (permalink)
Dennis
I have a sound problem with the left channel. The left front speaker is very
low, all the other speaker are at the proper volume. Problem is the same with
the on board audio or my Audigy 2 ZS card installed.
EVGA 680 sli 122-CK-NF68-A1, Intel Core 2 Duo E6600, OCZ @GB DDR2 1066, EVGA
GeForce 8800GTX, logitech Z-5300 5.1 speaker system.
I have removed and reloaded drivers and software, no effect. I have checked
all the speakers and connections to make sure they all work, and they do.
Anyone have any suggestions.
Thanks
Old 04-10-2007   #2 (permalink)
Cal Bear '66
Re: Sound issues with left channel
Since you have the same problem with both the on board audio controller
and the add-in Audigy, it would seem to be the speaker amplifier.
Try reversing the right and left channel speaker connections, and if the
problem is on the right channel, then you can be sure the problem is
with the speaker amplifier.
"Dennis" <Dennis@discussions.microsoft.com> wrote in message news:E6B77D8B-C234-4402-A984-B828439F6889@microsoft.com...
> Thanks
Old 04-10-2007   #3 (permalink)
Rick Rogers
Checked for a frayed cord?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
>very
> with
> EVGA
> checked
> Thanks
Old 04-11-2007   #4 (permalink)
Dennis
You were correct, the amp was bad. I setup the speakers on the monitor and
both channel work. Thanks
> very
> with
> EVGA
> checked
> do.
> > Thanks
Channel 9 to swallow Channel 8, Channel 10, and Coding4Fun Vista News
Phenom and triple channel memory issues General Discussion
Only Recording Left Channel Vista hardware & devices
sound channel problems Vista hardware & devices
Mute channel from sound device Vista hardware & devices
