| | No sound i have a new compaq presario with windows vista home premium and i am experiencing problems with realtek HD audio My sound is enabled in the BIOS start up... The only time i hear the sound ... which plays for about a minute is after the system goes into sleep mode and awakens and i then recieve a message ...a jack has been unplugged...a jack has been plugged i will really appreciate your help THANKS |
| | Re: No sound "SAM" <sameerxxx@hotmail.com> wrote in message news:1176308133.314377.163680@b75g2000hsg.googlegroups.com... > > i have a new compaq presario with windows vista home premium and i am > experiencing problems with realtek HD audio > > My sound is enabled in the BIOS start up... > The only time i hear the sound ... which plays for about a minute is > after the system goes into sleep mode > and awakens and i then recieve a message ...a jack has been > unplugged...a jack has been plugged > > i will really appreciate your help > > THANKS > I have a Sony Vaio VGN-FE45G/W and if I use the sleep mode, the sound is often lost after coming out of "sleep". So, AVOID using the sleep mode! Microsoft has published a fix for this KB929685, but when I try and install it, I get a message that says: "The update does not apply to your system". I did use the correct version (32 bit) of KB929685: http://support.microsoft.com/kb/929685/ So I'm not sure why my no audio with Vista problem shouldn't respond to KB929685? Anyway, I tried doing this: Control Panel: System: Device Manager: Sound video and game controllers: expand and right click on high definition audio device: then uninstall the driver. Then put the computer to sleep and power up again and the driver is reinstalled. This worked OK, but then since that time, if I use the sleep mode again, the sound is sometimes lost again. So I went through the uninstall procedure again, and went in and out of sleep, and it still didn't bring the sound back. GRRRR... but after a couple of complete power downs and reboots, the sound did reappear! So this uninstallation trick doesn't always work and persistence is needed! Uninstalling and reinstalling drivers is often the first step in solving lack of sound (and other) problems, but my post may not work for your problem. |
| | Re: No sound Can you help me about my soundCard my motherboard is ASUS P4V800D-X series including the soundCArd SOUNDMAX AD1888 codec any software for vista ultimate OS Plz!!! help me about this matter THANK YOU and GOD BLESS!! "Jack K" <Jack@kcaj.com> wrote in message news:upUXGYzfHHA.408@TK2MSFTNGP04.phx.gbl... > > "SAM" <sameerxxx@hotmail.com> wrote in message > news:1176308133.314377.163680@b75g2000hsg.googlegroups.com... >> >> i have a new compaq presario with windows vista home premium and i am >> experiencing problems with realtek HD audio >> >> My sound is enabled in the BIOS start up... >> The only time i hear the sound ... which plays for about a minute is >> after the system goes into sleep mode >> and awakens and i then recieve a message ...a jack has been >> unplugged...a jack has been plugged >> >> i will really appreciate your help >> >> THANKS >> > > I have a Sony Vaio VGN-FE45G/W and if I use the sleep mode, the sound is > often lost after coming out of "sleep". So, AVOID using the sleep mode! > Microsoft has published a fix for this KB929685, but when I try and > install it, I get a message that says: "The update does not apply to your > system". I did use the correct version (32 bit) of KB929685: > > http://support.microsoft.com/kb/929685/ > > So I'm not sure why my no audio with Vista problem shouldn't respond to > KB929685? > > Anyway, I tried doing this: > > Control Panel: System: Device Manager: Sound video and game controllers: > expand and right click on high definition audio device: then uninstall the > driver. Then put the computer to sleep and power up again and the driver > is reinstalled. This worked OK, but then since that time, if I use the > sleep mode again, the sound is sometimes lost again. So I went through the > uninstall procedure again, and went in and out of sleep, and it still > didn't bring the sound back. GRRRR... but after a couple of complete power > downs and reboots, the sound did reappear! So this uninstallation trick > doesn't always work and persistence is needed! > > Uninstalling and reinstalling drivers is often the first step in solving > lack of sound (and other) problems, but my post may not work for your > problem. > > |
| | Re: No sound On 11 avr, 18:15, "SAM" <sameer...@hotmail.com> wrote: > i have a newcompaqpresario with windows vista home premium and i am > experiencing problems with realtek HD audio > > My sound is enabled in the BIOS start up... > The only time i hear the sound ... which plays for about a minute is > after the system goes intosleepmode > and awakens and i then recieve a message ...a jack has been > unplugged...a jack has been plugged > > i will really appreciate your help > > THANKS Dear SAM, I want to give you the following info: I have a Compaq Presario SR1918, with realtek HD audio and Windows XP (not Vista). There is a problem with the audio output and the Headphones output: After powering on the PC, the loudspeaker (connected to the rear panel Audio output) works properly Then, if you connect a Headphone on the front panel Headphone output, the Headphone works properly, and no sound go to the loudspeaker (it seems to be normal). BUT, after this, if you disconnect the Headphones, the sound does not go back to the loudspeaker !!!! The sound seems to always go to the Headphones jack (because you can ear it if you reconnect the Headphone). I tried many parameters in the "Realtek configuration Audio HD" tools, without being able to get back the sound to the loudspeaker ! The only way I found is to restart the PC (it's a pity in 2007...) So, take care of your Headphone jack status, because the displayed warning "a jack has been plugged" is similar to the one I get during these actions.... Just try to insert/extract a jack in all your audio output jack, in case the internal switch is defective. good luck |
| | Re: No sound "Jack K" wrote: > > "SAM" <sameerxxx@hotmail.com> wrote in message > news:1176308133.314377.163680@b75g2000hsg.googlegroups.com... > > > > i have a new compaq presario with windows vista home premium and i am > > experiencing problems with realtek HD audio > > > > My sound is enabled in the BIOS start up... > > The only time i hear the sound ... which plays for about a minute is > > after the system goes into sleep mode > > and awakens and i then recieve a message ...a jack has been > > unplugged...a jack has been plugged > > > > i will really appreciate your help > > > > THANKS > > > > I have a Sony Vaio VGN-FE45G/W and if I use the sleep mode, the sound is > often lost after coming out of "sleep". So, AVOID using the sleep mode! > Microsoft has published a fix for this KB929685, but when I try and install > it, I get a message that says: "The update does not apply to your system". I > did use the correct version (32 bit) of KB929685: > > http://support.microsoft.com/kb/929685/ > > So I'm not sure why my no audio with Vista problem shouldn't respond to > KB929685? > > Anyway, I tried doing this: > > Control Panel: System: Device Manager: Sound video and game controllers: > expand and right click on high definition audio device: then uninstall the > driver. Then put the computer to sleep and power up again and the driver is > reinstalled. This worked OK, but then since that time, if I use the sleep > mode again, the sound is sometimes lost again. So I went through the > uninstall procedure again, and went in and out of sleep, and it still didn't > bring the sound back. GRRRR... but after a couple of complete power downs > and reboots, the sound did reappear! So this uninstallation trick doesn't > always work and persistence is needed! > > Uninstalling and reinstalling drivers is often the first step in solving > lack of sound (and other) problems, but my post may not work for your > problem. > > > |
| | #6 (permalink) |
| | Re: No sound "manilaboyph" wrote: > Can you help me about my soundCard my motherboard is ASUS P4V800D-X series > including the soundCArd SOUNDMAX AD1888 codec any software for vista > ultimate OS Plz!!! help me about this matter THANK YOU and GOD BLESS!! > > > > "Jack K" <Jack@kcaj.com> wrote in message > news:upUXGYzfHHA.408@TK2MSFTNGP04.phx.gbl... > > > > "SAM" <sameerxxx@hotmail.com> wrote in message > > news:1176308133.314377.163680@b75g2000hsg.googlegroups.com... > >> > >> i have a new compaq presario with windows vista home premium and i am > >> experiencing problems with realtek HD audio > >> > >> My sound is enabled in the BIOS start up... > >> The only time i hear the sound ... which plays for about a minute is > >> after the system goes into sleep mode > >> and awakens and i then recieve a message ...a jack has been > >> unplugged...a jack has been plugged > >> > >> i will really appreciate your help > >> > >> THANKS > >> > > > > I have a Sony Vaio VGN-FE45G/W and if I use the sleep mode, the sound is > > often lost after coming out of "sleep". So, AVOID using the sleep mode! > > Microsoft has published a fix for this KB929685, but when I try and > > install it, I get a message that says: "The update does not apply to your > > system". I did use the correct version (32 bit) of KB929685: > > > > http://support.microsoft.com/kb/929685/ > > > > So I'm not sure why my no audio with Vista problem shouldn't respond to > > KB929685? > > > > Anyway, I tried doing this: > > > > Control Panel: System: Device Manager: Sound video and game controllers: > > expand and right click on high definition audio device: then uninstall the > > driver. Then put the computer to sleep and power up again and the driver > > is reinstalled. This worked OK, but then since that time, if I use the > > sleep mode again, the sound is sometimes lost again. So I went through the > > uninstall procedure again, and went in and out of sleep, and it still > > didn't bring the sound back. GRRRR... but after a couple of complete power > > downs and reboots, the sound did reappear! So this uninstallation trick > > doesn't always work and persistence is needed! > > > > Uninstalling and reinstalling drivers is often the first step in solving > > lack of sound (and other) problems, but my post may not work for your > > problem. > > > > > > I have a HP Pavilion DV 6000 which worked perfectly with XP. After having installed the Vista upgrade, the internal loudspeakers quit working. Conexant audio... Same happened to a friend of mine using a Dell Notebook. Tried everything so far. Presume it is a Vista problem. Anything new? PS earphone jack and SPDIF work perfectly. |
| | #7 (permalink) |
| | Re: No sound I have the same on my HP Pavilion DV1760BR. Neither the Realtek driver has solved the problem. Any other suggestion? "thierry.public@free.fr" wrote: > On 11 avr, 18:15, "SAM" <sameer...@hotmail.com> wrote: > > i have a newcompaqpresario with windows vista home premium and i am > > experiencing problems with realtek HD audio > > > > My sound is enabled in the BIOS start up... > > The only time i hear the sound ... which plays for about a minute is > > after the system goes intosleepmode > > and awakens and i then recieve a message ...a jack has been > > unplugged...a jack has been plugged > > > > i will really appreciate your help > > > > THANKS > > Dear SAM, > > I want to give you the following info: > I have a Compaq Presario SR1918, with realtek HD audio and Windows XP > (not Vista). > There is a problem with the audio output and the Headphones output: > After powering on the PC, the loudspeaker (connected to the rear panel > Audio output) works properly > Then, if you connect a Headphone on the front panel Headphone output, > the Headphone works properly, and no sound go to the loudspeaker (it > seems to be normal). > BUT, after this, if you disconnect the Headphones, the sound does not > go back to the loudspeaker !!!! > The sound seems to always go to the Headphones jack (because you can > ear it if you reconnect the Headphone). > I tried many parameters in the "Realtek configuration Audio HD" tools, > without being able to get back the sound to the loudspeaker ! > The only way I found is to restart the PC (it's a pity in 2007...) > > So, take care of your Headphone jack status, because the displayed > warning "a jack has been plugged" is similar to the one I get during > these actions.... > > Just try to insert/extract a jack in all your audio output jack, in > case the internal switch is defective. > > good luck > > |
| | #8 (permalink) |
| | Re: No sound I have the same problem with my Pavilion DV1760BR. I have tried to install a sound drive from HP site and from Windows Update, there is an icon and at Control Panel the message is that the driver is OK, but I have no sound. HP Technical Suport said that it can be a phisical failure. Does anyone have a similar situation? Thank you! "vistauser" wrote: > > > "manilaboyph" wrote: > > > Can you help me about my soundCard my motherboard is ASUS P4V800D-X series > > including the soundCArd SOUNDMAX AD1888 codec any software for vista > > ultimate OS Plz!!! help me about this matter THANK YOU and GOD BLESS!! > > > > > > > > "Jack K" <Jack@kcaj.com> wrote in message > > news:upUXGYzfHHA.408@TK2MSFTNGP04.phx.gbl... > > > > > > "SAM" <sameerxxx@hotmail.com> wrote in message > > > news:1176308133.314377.163680@b75g2000hsg.googlegroups.com... > > >> > > >> i have a new compaq presario with windows vista home premium and i am > > >> experiencing problems with realtek HD audio > > >> > > >> My sound is enabled in the BIOS start up... > > >> The only time i hear the sound ... which plays for about a minute is > > >> after the system goes into sleep mode > > >> and awakens and i then recieve a message ...a jack has been > > >> unplugged...a jack has been plugged > > >> > > >> i will really appreciate your help > > >> > > >> THANKS > > >> > > > > > > I have a Sony Vaio VGN-FE45G/W and if I use the sleep mode, the sound is > > > often lost after coming out of "sleep". So, AVOID using the sleep mode! > > > Microsoft has published a fix for this KB929685, but when I try and > > > install it, I get a message that says: "The update does not apply to your > > > system". I did use the correct version (32 bit) of KB929685: > > > > > > http://support.microsoft.com/kb/929685/ > > > > > > So I'm not sure why my no audio with Vista problem shouldn't respond to > > > KB929685? > > > > > > Anyway, I tried doing this: > > > > > > Control Panel: System: Device Manager: Sound video and game controllers: > > > expand and right click on high definition audio device: then uninstall the > > > driver. Then put the computer to sleep and power up again and the driver > > > is reinstalled. This worked OK, but then since that time, if I use the > > > sleep mode again, the sound is sometimes lost again. So I went through the > > > uninstall procedure again, and went in and out of sleep, and it still > > > didn't bring the sound back. GRRRR... but after a couple of complete power > > > downs and reboots, the sound did reappear! So this uninstallation trick > > > doesn't always work and persistence is needed! > > > > > > Uninstalling and reinstalling drivers is often the first step in solving > > > lack of sound (and other) problems, but my post may not work for your > > > problem. > > > > > > > > > > I have a HP Pavilion DV 6000 which worked perfectly with XP. > After having installed the Vista upgrade, the internal loudspeakers quit > working. Conexant audio... Same happened to a friend of mine using a Dell > Notebook. Tried everything so far. Presume it is a Vista problem. Anything > new? > PS earphone jack and SPDIF work perfectly. |
| | #9 (permalink) |
| | Re: No sound Right click on the Speaker icon in the Notification Area of the Taskbar and select Playback Devices. Right click in the Playback Devices window and check both "Show Disabled Devices" and "Show Disconnected Devices" Select Speakers and press the Set Default button. Use the Configure and Properties button to set up your speakers. Use the Sounds tab to confirm you have sound. Also, in the Notification Area, right click on the RED speaker icon and select Sound Manager, click the Device advanced settings link in the upper right corner and make your selections. Go through all the tabs and set up your sound and input selections. -- I Bleed Blue and Gold GO BEARS! "Alekra" <Alekra@discussions.microsoft.com> wrote in message news:6D1DEE90-9989-483E-A8D4-39F2BD00880C@microsoft.com... > > I have the same problem with my Pavilion DV1760BR. I have tried to install a > sound drive from HP site and from Windows Update, there is an icon and at > Control Panel the message is that the driver is OK, but I have no sound. HP > Technical Suport said that it can be a phisical failure. Does anyone have a > similar situation? > > Thank you! > > > > "vistauser" wrote: > >> >> >> "manilaboyph" wrote: >> >> > Can you help me about my soundCard my motherboard is ASUS P4V800D-X series >> > including the soundCArd SOUNDMAX AD1888 codec any software for vista >> > ultimate OS Plz!!! help me about this matter THANK YOU and GOD BLESS!! >> > >> > >> > >> > "Jack K" <Jack@kcaj.com> wrote in message >> > news:upUXGYzfHHA.408@TK2MSFTNGP04.phx.gbl... >> > > >> > > "SAM" <sameerxxx@hotmail.com> wrote in message >> > > news:1176308133.314377.163680@b75g2000hsg.googlegroups.com... >> > >> >> > >> i have a new compaq presario with windows vista home premium and i am >> > >> experiencing problems with realtek HD audio >> > >> >> > >> My sound is enabled in the BIOS start up... >> > >> The only time i hear the sound ... which plays for about a minute is >> > >> after the system goes into sleep mode >> > >> and awakens and i then recieve a message ...a jack has been >> > >> unplugged...a jack has been plugged >> > >> >> > >> i will really appreciate your help >> > >> >> > >> THANKS >> > >> >> > > >> > > I have a Sony Vaio VGN-FE45G/W and if I use the sleep mode, the sound is >> > > often lost after coming out of "sleep". So, AVOID using the sleep mode! >> > > Microsoft has published a fix for this KB929685, but when I try and >> > > install it, I get a message that says: "The update does not apply to your >> > > system". I did use the correct version (32 bit) of KB929685: >> > > >> > > http://support.microsoft.com/kb/929685/ >> > > >> > > So I'm not sure why my no audio with Vista problem shouldn't respond to >> > > KB929685? >> > > >> > > Anyway, I tried doing this: >> > > >> > > Control Panel: System: Device Manager: Sound video and game controllers: >> > > expand and right click on high definition audio device: then uninstall >> > > the >> > > driver. Then put the computer to sleep and power up again and the driver >> > > is reinstalled. This worked OK, but then since that time, if I use the >> > > sleep mode again, the sound is sometimes lost again. So I went through >> > > the >> > > uninstall procedure again, and went in and out of sleep, and it still >> > > didn't bring the sound back. GRRRR... but after a couple of complete >> > > power >> > > downs and reboots, the sound did reappear! So this uninstallation trick >> > > doesn't always work and persistence is needed! >> > > >> > > Uninstalling and reinstalling drivers is often the first step in solving >> > > lack of sound (and other) problems, but my post may not work for your >> > > problem. >> > > >> > > >> > >> > I have a HP Pavilion DV 6000 which worked perfectly with XP. >> After having installed the Vista upgrade, the internal loudspeakers quit >> working. Conexant audio... Same happened to a friend of mine using a Dell >> Notebook. Tried everything so far. Presume it is a Vista problem. Anything >> new? >> PS earphone jack and SPDIF work perfectly. |
| | #10 (permalink) |
| | Re: No sound Cal Bear '66, I've been looking through tons of posts for a couple of weeks now trying to find a solution for my sound problem. Yours have been among the most useful posts for things to try. I have 3 Problems Problem 1: Most .wav sounds are barely audible if at all with volume turned up to 100% (specs and details below). Yes I've pushed all available volume sliders up to 100%. Problem 2: WMP11 does not recognize midi files as music and won't list them with my other music - there do not appear to be any codecs available for this on the Windows Media forum - how can I get them to be listed in the music part of my library? Problem 3: A few times I have seen where you refer to two different Speaker Icons in the "notification area of the Taskbar" - are you talking about the System Tray area? The reason I ask is that I only ever see the one Speaker Icon - I never ever see a "red" Speaker Icon. Could I be missing some critical software element which could be a factor in my problems or am I just not looking in the right spot for this icon? --on to problem 1, the big issue-- For the record and comparison purposes for all monitoring these discussions, here are my specs and my attempts at resolution for Problem 1 (Most .wav sounds are barely audible if at all with volume turned up to 100%): Mine is a new laptop (rather than an upgrade). A precious few sounds come through loud and clear, but virtually all of the default Windows sound scheme sounds are barely audible. Sometimes movie clips are audible at about 50%, sometimes not audible at all. Some CDs audible at about 50%. System start up music audible but clipped and choppy. Op System: Windows Vista(TM) Home Premium Manufacturer: Sony Electronics, Inc. Model: VAIO VGN-CR120E Processor: Intel(R) Core(TM)2 Duo CPU T7100 @ 1.80GHz 1.80 GHz Memory (RAM): 2038 MB (1.99 GB RAM) Mobile Intel(R) 965 Express Chipset Family System Type: 32-bit Operating System Realtek High Definition Audio Driver Provider: Realtek Semiconductor Corp. Driver Date: 3/26/2007 Driver Version: 6.01.5391 Digital Signer: microsoft windows hardware compatibility publisher and I have updated the RealTek driver Updated configuration: 8/19/2007 Applied 1.72 Driver Date: 8/10/2007 Driver Version: 6.0.1.5464 After this upgrade, I went back in to WMP-11 and in organizing the Library, I realized some very interesting things: The .wav sounds that tend NOT to be audible are the ones installed on this Vista 32-bit machine, however they become barely audible at about 70% now instead of 100%. The .wav sounds I pulled over from my previous XP ARE LOUDER (though not as loud and clear as they were on that XP - probably the internal speakers on this machine vs the ones on that one), and they are the same file names as the soft one but with an earlier file date. The .wav sounds that I pulled over originally on one of my Win95 (yes 95) machines ARE LOUDEST OF ALL. I sure wish I had ALL of the system sounds from those older machines, but alas I do not - only about 10 of them. After that update, CDs (wma) are playing as loudly and clearly as these speakers allow now, but video clips are still unpredictable - while IN WMP if they are in my library, they play - if I'm on the internet, they are either all or nothing (video with no sound, or video with full sound). Were these newer system .wavs meant to be played back on the 64-bit Vistas? Would that cause mine and other people's problems on the 32-bit Vistas? When I was looking for a Vista codec for the midi files, I didn't see any "free" Vista codecs at all and only 2 that had to be purchased but neither had anything to do with any of my problems. Am I looking for these in the wrong place? I'll close now ===================================================== "Cal Bear '66" wrote: > Right click on the Speaker icon in the Notification Area of the Taskbar and > select Playback Devices. Right click in the Playback Devices window and check > both "Show Disabled Devices" and "Show Disconnected Devices" Select Speakers > and press the Set Default button. Use the Configure and Properties button to set > up your speakers. Use the Sounds tab to confirm you have sound. > > Also, in the Notification Area, right click on the RED speaker icon and select > Sound Manager, click the Device advanced settings link in the upper right corner > and make your selections. Go through all the tabs and set up your sound and > input selections. > > -- > I Bleed Blue and Gold > GO BEARS! > > > "Alekra" <Alekra@discussions.microsoft.com> wrote in message > news:6D1DEE90-9989-483E-A8D4-39F2BD00880C@microsoft.com... > > > > I have the same problem with my Pavilion DV1760BR. I have tried to install a > > sound drive from HP site and from Windows Update, there is an icon and at > > Control Panel the message is that the driver is OK, but I have no sound. HP > > Technical Suport said that it can be a phisical failure. Does anyone have a > > similar situation? > > > > Thank you! > > > > > > > > "vistauser" wrote: > > > >> > >> > >> "manilaboyph" wrote: > >> > >> > Can you help me about my soundCard my motherboard is ASUS P4V800D-X series > >> > including the soundCArd SOUNDMAX AD1888 codec any software for vista > >> > ultimate OS Plz!!! help me about this matter THANK YOU and GOD BLESS!! > >> > > >> > > >> > > >> > "Jack K" <Jack@kcaj.com> wrote in message > >> > news:upUXGYzfHHA.408@TK2MSFTNGP04.phx.gbl... > >> > > > >> > > "SAM" <sameerxxx@hotmail.com> wrote in message > >> > > news:1176308133.314377.163680@b75g2000hsg.googlegroups.com... > >> > >> > >> > >> i have a new compaq presario with windows vista home premium and i am > >> > >> experiencing problems with realtek HD audio > >> > >> > >> > >> My sound is enabled in the BIOS start up... > >> > >> The only time i hear the sound ... which plays for about a minute is > >> > >> after the system goes into sleep mode > >> > >> and awakens and i then recieve a message ...a jack has been > >> > >> unplugged...a jack has been plugged > >> > >> > >> > >> i will really appreciate your help > >> > >> > >> > >> THANKS > >> > >> > >> > > > >> > > I have a Sony Vaio VGN-FE45G/W and if I use the sleep mode, the sound is > >> > > often lost after coming out of "sleep". So, AVOID using the sleep mode! > >> > > Microsoft has published a fix for this KB929685, but when I try and > >> > > install it, I get a message that says: "The update does not apply to your > >> > > system". I did use the correct version (32 bit) of KB929685: > >> > > > >> > > http://support.microsoft.com/kb/929685/ > >> > > > >> > > So I'm not sure why my no audio with Vista problem shouldn't respond to > >> > > KB929685? > >> > > > >> > > Anyway, I tried doing this: > >> > > > >> > > Control Panel: System: Device Manager: Sound video and game controllers: > >> > > expand and right click on high definition audio device: then uninstall > >> > > the > >> > > driver. Then put the computer to sleep and power up again and the driver > >> > > is reinstalled. This worked OK, but then since that time, if I use the > >> > > sleep mode again, the sound is sometimes lost again. So I went through > >> > > the > >> > > uninstall procedure again, and went in and out of sleep, and it still > >> > > didn't bring the sound back. GRRRR... but after a couple of complete > >> > > power > >> > > downs and reboots, the sound did reappear! So this uninstallation trick > >> > > doesn't always work and persistence is needed! > >> > > > >> > > Uninstalling and reinstalling drivers is often the first step in solving > >> > > lack of sound (and other) problems, but my post may not work for your > >> > > problem. > >> > > > >> > > > >> > > >> > I have a HP Pavilion DV 6000 which worked perfectly with XP. > >> After having installed the Vista upgrade, the internal loudspeakers quit > >> working. Conexant audio... Same happened to a friend of mine using a Dell > >> Notebook. Tried everything so far. Presume it is a Vista problem. Anything > >> new? > >> PS earphone jack and SPDIF work perfectly. > > |
| distorted sound in vista/createiv x-fi titanium sound card | Sound & Audio | |||
No sound when playing music or video, but internet sound works fine | Sound & Audio | |||
| Setting per Application Sound Output, or Per Sound Type Outputs... | Vista General | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
| Vista x64 RC2 - Sound Card/Amplifier - DTS Test Sound (Audigy 2 ZS SPDIF) | Vista General | |||
