| | Fusion 5 USB HDTV Tuner Anyone had any luck getting this to work? I even tried their new beta software and drivers, but I can only get part way through scanning channels before the driver blows up. Similar problem trying it with Snapstream Beyond TV. I'll contact the vendor, but thought someone might have had luck. Thanks, Tom |
| | RE: Fusion 5 USB HDTV Tuner "Tom Scales" wrote: > Anyone had any luck getting this to work? I even tried their new beta > software and drivers, but I can only get part way through scanning channels > before the driver blows up. Similar problem trying it with Snapstream > Beyond TV. > > I'll contact the vendor, but thought someone might have had luck. > > Thanks, > > Tom > |
| | RE: Fusion 5 USB HDTV Tuner I have the Fusion HDTV 2 Tuner as a PCI card in my system, and am having the same problem regardless of what version of the software I have used since installing the VISTA beta, I have tried to install using the COMPATABILITY mode as WinXP, and qot to no avail either. I get part way through the scan which seems to be automatically trying to do a DIGITAL channel scan first, even though I have told the software I want it to do a ANALOG single input. Part way through the scan it seems to be finding some sort of signal on some of the channels every 3rd or 4th, but then the whole thing freezes, or you know at some point that something isn't right in Kansas, and you hault the whole thing becuase you know something has gone astray. I did by some freak of some odd search is was doing that seemed to imply that I might need to have an physical ANALOG TV tuner card to be installed on the system and then the thing will work sucessfully, I haven't tried this yet to confirm this but I do happen to have a TV card that did work successfully under WinXP that I might be able to dig up out of my computer old card stuff laying around to confirm that this works. I believe I did a search using the terms "VISTA FUSION HDTV" when I ran into that as a possible work around. The Fusion 5 is a software HDTV device too I believe. The Fusion HDTV 2 that I have is and that might have something to do with it. If you get your USB Fusion to work I really want to know how you do it and if it works I might just replace mine, which if anyone out there has never checked into the Fusion devices I highly recommend they look into the, they are quite a remarkable device for the price. http://www.fusionhdtv.co.kr/ENG/Products/ "Tom Scales" wrote: > Anyone had any luck getting this to work? I even tried their new beta > software and drivers, but I can only get part way through scanning channels > before the driver blows up. Similar problem trying it with Snapstream > Beyond TV. > > I'll contact the vendor, but thought someone might have had luck. > > Thanks, > > Tom > |
| | Re: Fusion 5 USB HDTV Tuner Media Center DOES require an analog tuner configured first. It can't be the analog side of the Fusion. That's not my problem though. I wrote Dvico and they said they were working on a Vista driver. Said they'd let me know. I'm trying to get it to work with BeyondTV, not MCE, so I don't need an analog tuner (although I have a few ![]() Tom "RF: Fusion HDTV 2" <RFFusionHDTV2@discussions.microsoft.com> wrote in message news:28A6F67F-2C42-462C-86A6-BB80FBF6D69D@microsoft.com... >I have the Fusion HDTV 2 Tuner as a PCI card in my system, and am having >the > same problem regardless of what version of the software I have used > since > installing the > VISTA beta, I have tried to install using the COMPATABILITY mode as > WinXP, > and qot to no avail either. I get part way through the scan which seems > to > be automatically trying to do a DIGITAL channel scan first, even though > I > have told the > software I want it to do a ANALOG single input. Part way through the scan > it seems to be finding some sort of signal on some of the channels every > 3rd > or 4th, but then > the whole thing freezes, or you know at some point that something isn't > right in Kansas, and you hault the whole thing becuase you know > something > has gone astray. > > I did by some freak of some odd search is was doing that seemed to imply > that I might need to have an physical ANALOG TV tuner card to be installed > on > the system > and then the thing will work sucessfully, I haven't tried this yet to > confirm this but > I do happen to have a TV card that did work successfully under WinXP that > I > might > be able to dig up out of my computer old card stuff laying around to > confirm that this > works. I believe I did a search using the terms "VISTA FUSION HDTV" > when > I ran > into that as a possible work around. > > The Fusion 5 is a software HDTV device too I believe. The Fusion HDTV 2 > that I have is and that might have something to do with it. > > If you get your USB Fusion to work I really want to know how you do it and > if it works > I might just replace mine, which if anyone out there has never checked > into the Fusion devices I highly recommend they look into the, they are > quite > a remarkable device for the price. > http://www.fusionhdtv.co.kr/ENG/Products/ > > > "Tom Scales" wrote: > >> Anyone had any luck getting this to work? I even tried their new beta >> software and drivers, but I can only get part way through scanning >> channels >> before the driver blows up. Similar problem trying it with Snapstream >> Beyond TV. >> >> I'll contact the vendor, but thought someone might have had luck. >> >> Thanks, >> >> Tom >> |
| Which HDTV tuner cards are best for my 64 bit computer? | Graphic cards | |||
| Use Vista Ultimate PC as a dual-tuner HDTV DVR | Vista music pictures video | |||
| Which HDTV Tuner card to use as a DVR with digital cable | Media Center | |||
| Dvico Fusion PCI TV Tuner | Vista hardware & devices | |||
| Does the Fusion 5 HDTV QAM tuner work with Vista? | Vista music pictures video | |||
