Vista - I have problems when printing using a shared printer
Old 04-13-2007   #1 (permalink)
Conan
Hello to everybody. I'm from Spain and I have a problem.
I have bought a PC with Windows Vista because I wanted to replace another PC
with Windows 98. Windows 98'PC have a shared printer and I use this printer
to print from other pc with Windows XP. When I installed Windows Vista'PC I
had a problem with the printer. Now I can print with Windows Vista'Pc
(printer is directly connected to this PC) but I can't print with Windows
Xp'PC. Both PC's are in a Network and they are connected to a ADSL router.
¿Con you help me? Thank you very much.
Old 04-14-2007   #2 (permalink)
Rick Rogers
Re: I have problems when printing using a shared printer
First two things:
1) Did you share the printer under Vista? Are you able to share files from
it to XP?
2) Did you remap the network printer path in XP? You know, from
\\Win98\printer to \\WinVista\printer?
Best of Luck,
Rick Rogers, aka "Nutcase" - Microsoft MVP
http://mvp.support.microsoft.com/
Windows help - www.rickrogers.org
"Conan" <Conan@discussions.microsoft.com> wrote in message
news:E338232E-8F65-4F62-82A4-C48D8DD0496F@microsoft.com...
> PC
> printer
> I
Old 04-15-2007   #3 (permalink)
Conan
Hello:
Thank you very much for your answers.
1. Yes, my printer is shared under Vista. But I can't see it from XP and I
have shared several files in Vista but I don't see them from XP. In addition,
when I use command ping from Vista I have response from Xp but If i use ping
command in XP I haven't response from Vista.
2. Well, it was not necessary because the name of the machine is the same.
But I tried to remap again the printer and XP can't see it so it can't remap
it.
"Rick Rogers" wrote:
> Hi,
> First two things:
> it to XP?
> Best of Luck,
> > PC
> > printer
> > I
Old 04-15-2007   #4 (permalink)
Rick Rogers
Hi Conan,
Click start on the Vista machine and type 'network and sharing center' and
run the entry in the menu, check your settings here. At least the first four
options need to be enabled.
Best of Luck,
news:FC9659A5-A6F4-40ED-912B-34774E82B015@microsoft.com...
> Hello:
> addition,
> ping
> remap
> it.
>> Hi,
>> First two things:
>> from
>> it to XP?
>> Best of Luck,
>> > another
>> > PC
>> > printer
>> > Vista'PC
>> > I
>> > Windows
>> > router.
Old 04-20-2007   #5 (permalink)
Conan
Hello Rick:
Well, I have done all you said and i have noticed than option number three
is not activated but i don't think it's necesarry because i don't want to
share files. I only want to share a printer. ¿Am I wrong?
Than you very much
> Hi Conan,
> Best of Luck,
> > Hello:
> > addition,
> > ping
> > remap
> > it.
> >> Hi,
> >> First two things:
> >> from
> >> it to XP?
> >> Best of Luck,
> >> > another
> >> > PC
> >> > printer
> >> > Vista'PC
> >> > I
> >> > Windows
> >> > router.
Old 04-20-2007   #6 (permalink)
Rick Rogers
Yes, you are correct. Public folder sharing does not need to be on.
Best of Luck,
news:11F973A8-7804-4214-9114-6CFA952456F8@microsoft.com...
> Hello Rick:
> Than you very much
>> Hi Conan,
>> and
>> four
>> Best of Luck,
>> > Hello:
>> > and I
>> > addition,
>> > ping
>> > same.
>> > remap
>> > it.
>> >> Hi,
>> >> First two things:
>> >> from
>> >> it to XP?
>> >> Best of Luck,
>> >> > another
>> >> > PC
>> >> > printer
>> >> > Vista'PC
>> >> > I
>> >> > Vista'Pc
>> >> > Windows
>> >> > router.
Vista Printing to Shared XP Printer Vista print fax & scan
Printing to an XP shared printer Vista print fax & scan
Problems printing to shared printer Vista networking & sharing
Printing problems from shared XP printer to a Vista PC Vista print fax & scan
Glacial Printing from Mac Shared Printer Vista print fax & scan
