What is Data Interface in Other Devices ?
  1.    13 Apr 2007 #1
    John Guest
    Running Vista 32-bit Enterprise...
    In the Device Manager, under Other Devices, I see a device called Data
    Interface. It's current state is:
    "The drivers for this device are not installed. (Code 28)"
    I don't know what this is or how to find a driver for it, but I suspect that
    it is causing problems with my Dell 946 AIO printer install. The print
    drivers install fine, and I can print with no problems. What I can't do is
    install the All-In-One Dell software that enables me to control the scanner
    functions. The install complains about the USB connection.
    I suspect that this mysterious Data Interface plays a role in my problem.
    Here are a few of the properties of the device:
    0000.001d.0007.002.002.000.000.000.000
    Hardware Ids:
    USB\VID_413C&PID_8114&REV_0000&MI_01
    USB\VID_413C&PID_8114&MI_01
    Compatible Ids:
    USB\Class_ff&SubClass_ff&Prot_ff
    USB\Class_ff
    Config Flags
    00000040
    CONFIGFLAG_FAILEDINSTALL
    Physical Device Object name:
    \Device\00000074
    Capabilities:
    00000000
    Bus type guid:
    {9d7debbc-c85d-11d1-9eb4-006008c3a19a}
    Legacy bus type:
    0000000F
    Bus number:
    00000000
    Enumerator:
    USB
    Address:
    00000002
    Power data:
    Current power state:
    D3
    Power capabilities:
    0000007F
    PDCAP_D0_SUPPORTED
    PDCAP_D1_SUPPORTED
    PDCAP_D2_SUPPORTED
    PDCAP_D3_SUPPORTED
    PDCAP_WAKE_FROM_D0_SUPPORTED
    PDCAP_WAKE_FROM_D1_SUPPORTED
    PDCAP_WAKE_FROM_D2_SUPPORTED
    Power state mappings:
    S0 -> D0
    S1 -> D3
    S2 -> D3
    S3 -> D3
    S4 -> D3
    S5 -> D3
    Install state:
    00000002
    Device Instance Path:
    USB\VID_413C&PID_8114&MI_01\7&22D676D1&0&0001
    DevNode status:
    01802400
    DN_HAS_PROBLEM
    DN_DISABLEABLE
    DN_NT_ENUMERATOR
    DN_NT_DRIVER
    Problem code:
    0000001C
    Parent:
    USB\VID_413C&PID_8114\6&28dac56e&0&2
    Siblings:
    USB\VID_413C&PID_8114&MI_00\7&22d676d1&0&0000
    Install error:
    There is no driver selected for the device information set or element.
    E0000203
    Lower logo version:
    6.0
    Any thoughts?
    TIA,
    John
  2.    07 Aug 2008 #2
    Jessica P. Guest
    RE: What is Data Interface in Other Devices ?
    Hi John, the bangs in Device Manager are waiting for you to install the driver: Dell Wireless 5700 VZW Mobile Broadband CDMA EVDO MiniCard; Dell driver file# R159127 (if you're running XP). Here's the direct link: http://ftp.us.dell.com/comm/Dell_mul...02_R159127.exe
    God bless...
    - Jessica
    Dell Service Professional 1
    Florida USA
Data Interface (other Device) in XP
I have a seriouse problem with my Dell Latitude D600 USB port (OS: windows XP), such that i can not use any USB devices such as printer, mouse, flash...
Chillout Room
mysterious "data interface"
hello, im not sure if anybodys gonna know what im talking about because im a swedish vista-user and therefore using a swedish usb-modem. i know...
Network & Sharing
Access to vista component devices of playback devices likemicrophone, linein, front mic etc in vc++
I want to access the playback devices->Speakers->properties->levels tab -> (microphone, front mic, linein etc) I want to access these and change...
Vista hardware & devices
Access vista component devices of playback devices like microphone,linein, front mic etc in vc++
Vista General
Do U3 Data Traveler Devices (Thumbdrives) work under Vista?
Dear friends: Do U3 Data Traveler Devices (Thumbdrives) work under Vista? At least, mine didn't started up. I didn't have any problem to access...
Vista General
No compatibility data on 3 devices
Hi all, I just ran the Win Upgrade Advisor, and there was no hardware or software problem, but there were 3 devices for which it says there was...
Vista installation & setup
I also posted this on the setup board. Hi all, I just ran the Win Upgrade Advisor, and there was no hardware or software problem, but there...
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
