Vista - Big,Problem
Old 06-15-2006   #1 (permalink)
Greek Soul
Big,Problem
I Have an Asus Motherboard(P5GV-MX)that includes a sound card.I had Windows
xp,and i installed sound max,so i could play music.But now I have the beta 2
of Vista and i can't install sound Max.what to do???is there a program that
can help???
Please,Help
This post is a suggestion for Microsoft, and Microsoft responds to the
suggestions with the most votes. To vote for this suggestion, click the "I
Agree" button in the message pane. If you do not see the button, follow this
link to open the suggestion in the Microsoft Web-based Newsreader and then
click "I Agree" in the message pane.
http://windowshelp.microsoft.com/com...rdware_devices
Old 06-15-2006   #2 (permalink)
if you are using Vista x64, try the beta 5.10.02.4151 for WinXP x64 available here:
http://support.asus.com/download/dow...Language=en-us
If you get an operating system error on install, you'll need to change the file "Setup.exe" to XP SP2 Compatibility Mode by highlighting it, right-clicking, choosing Properties and navigating to the Compatibility Tab. check the box and click Ok.
Let me know if this does not work, in which case you might need to disable either User Access Control or Driver Signing at least temporarily.
Quote  Quote: Originally Posted by Greek Soul
can help???
Please,Help
Old 06-16-2006   #3 (permalink)
Greek Soul
Re: Big,Problem
It Worked! Thank You
> available here:
> temporarily.
> > Windows
> > beta 2
> > that
> > can help???
> > Please,Help
> > "I
> > this
> > then
> > http://tinyurl.com/s5lzp
> hawkeyefan
> hawkeyefan's Profile: http://forums.yourdomain.com.au/member.php?userid=34
> View this thread: http://forums.yourdomain.com.au/showthread.php?t=5659
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
