| | Vista - DirectX problems with ATI Mobility Radeon X700 and Games |
| 06-15-2006 | #1 |
| | DirectX problems with ATI Mobility Radeon X700 and Games I'm running the following system: Toshiba Satellite M70-148: Processor: Intel Pentium M processor 2.00GHz Memory(RAM): 1,00 GB Primary harddisk: 93.16 GB Graphics: ATI Mobility Radeon X700 Gaming Graphics: 256 MB Memory Windows Vista Beta 2 Evaluation copy Build 5384. The graphic card is running on the last ATI drives with the Catalist running. I installed some games and always get the messege that it has a problem with DirectX. The last one happend with Command & Conquer Generals. The messege is: "Please make sure you have DirectX 8.1 or higher installed. Also verify that your video card meets the minimum requirements." All windows programs are running well but all games have the DirectX problem. I installed and uninstalled it some times but it didn't help. How can i solve this problem? |
| My System Specs |
| 06-15-2006 | #2 |
| | RE: DirectX problems with ATI Mobility Radeon X700 and Games many people are having the same problem. im running a ati x700 mobility too. Just get into your device manager and right click your graphic card an select properties. I think the error is called code 43. Just type in "ati" on the top of the forums! i also tried the newest "vista driver" provided by ati "Maverick" wrote: > I'm running the following system: > > Toshiba Satellite M70-148: > Processor: Intel Pentium M processor 2.00GHz > Memory(RAM): 1,00 GB > Primary harddisk: 93.16 GB > Graphics: ATI Mobility Radeon X700 > Gaming Graphics: 256 MB Memory > > Windows Vista Beta 2 Evaluation copy Build 5384. > > The graphic card is running on the last ATI drives with the Catalist running. > I installed some games and always get the messege that it has a problem with > DirectX. The last one happend with Command & Conquer Generals. > > The messege is: > > "Please make sure you have DirectX 8.1 or higher installed. Also verify that > your video card meets the minimum requirements." > > All windows programs are running well but all games have the DirectX problem. > > I installed and uninstalled it some times but it didn't help. > > How can i solve this problem? |
| My System Specs |
| 06-21-2006 | #3 |
| | RE: DirectX problems with ATI Mobility Radeon X700 and Games I have the problem solved. In the "Compatibility" tab "Properties" screen of the link to the game I changed the following things: I turned on: "Run this program in Compatibility mode for: Windows XP (SP2)" "Disable Desktop composition" "Disable display Scaling on high DPI Settings" Now C&C Generals is working correct, also Zero Hour is running. "Maverick" wrote: > I'm running the following system: > > Toshiba Satellite M70-148: > Processor: Intel Pentium M processor 2.00GHz > Memory(RAM): 1,00 GB > Primary harddisk: 93.16 GB > Graphics: ATI Mobility Radeon X700 > Gaming Graphics: 256 MB Memory > > Windows Vista Beta 2 Evaluation copy Build 5384. > > The graphic card is running on the last ATI drives with the Catalist running. > I installed some games and always get the messege that it has a problem with > DirectX. The last one happend with Command & Conquer Generals. > > The messege is: > > "Please make sure you have DirectX 8.1 or higher installed. Also verify that > your video card meets the minimum requirements." > > All windows programs are running well but all games have the DirectX problem. > > I installed and uninstalled it some times but it didn't help. > > How can i solve this problem? |
| My System Specs |
| Similar Threads for: DirectX problems with ATI Mobility Radeon X700 and Games | ||||
| Ati mobility radeon x700 on toshiba sat pro m70-113-Screen problem | Graphic cards | |||
| DirectX problems with ATI Mobility Radeon X700 and Games | Vista hardware & devices | |||
| DirectX Problems with ATI Mobility Radeon X700 and games. | Vista hardware & devices | |||
