USB Wireless NIC
  1. #1
    Donny Broome Guest
    USB Wireless NIC
    Will someone please suggest a USB Wireless NIC that they've personally used
    successfully with Vista? My older (cheap) Linksys model (designed for XP) is
    not getting the job done.
    Thank You,
    Donny Broome
    www.broomeman.com/tech
  2. #2
    estoad2 Guest
    RE: USB Wireless NIC
    Sorry, no personal experience, but according to D-Link site, DWA-130 Wireless
    "N" USB adapter, and the DWL-G122 Wireless "G" Compact Adapters are available
    for Vista.
    > Thank You,
    > Donny Broome
  3. #3
    phillfri Guest
    Believe it or not, my old Linksys WUSB12 works great with WIndows Vista just
    fine :>) Just plugged it in and Vista downloaded a compatible driver. Kudos
    to Cisco for providing Vista support for this very old 11b model. (It was the
    only one out of 4 USB wireless devices I have that would work with Vista. The
    manufacturers of the other 3 models say they won't even bother to provide
    Vista drivers.)
    But - to the question. You can get a Vista Certified ZyXel G-202 USB
    wireless device at Newegg for circa $25.00, but I think they are currently
    out of stock. It does work fairly well, albeit I've been having issues with
    my new Dell Vista machine and its hard to tell exactly where the problem
    lies. Nevertheless, ZyXel has an excellent reputation for producing quality
    products and supporting them - though no manufacturer is going to bring all
    their old products forward to Vista. Make sure you visit the manufacturer's
    web site to check for Vista compatibility.
    > Thank You,
    > Donny Broome
  4. #4
    Donny Broome Guest
    Re: USB Wireless NIC
    Thank you.
    "phillfri" <phillfri@discussions.microsoft.com> wrote in message
    news:9E5E4A1D-A4FC-40F4-9EB2-34B4EFFAD99E@microsoft.com...
    > just
    > Kudos
    > the
    > The
    > Vista drivers.)
    > with
    > quality
    > all
    > manufacturer's
    >> used
    >> is
    >> Thank You,
    >> Donny Broome
  5. #5
    phillfri Guest
    If you get a ZyXel G-202 make sure you use the driver from the CD or their
    web site. Vista will try to automatically install a driver from its driver
    database, but that driver WILL cause Vista to bomb out (BSODs).
    > Thank you.
    > > just
    > > Kudos
    > > the
    > > The
    > > Vista drivers.)
    > > with
    > > quality
    > > all
    > > manufacturer's
    > >> used
    > >> is
    > >> Thank You,
    > >> Donny Broome
  6. #6
    Robert Guest
    A great in-expensive USB Wireless NIC is an Encore ENUWI-G2.
    Vista drivers on their website encore-usa.com
    I've used this NIC on all sorts of hardware/software. I know it to work well
    with Vista.
    > Thank You,
    > Donny Broome
USB Wireless NIC problems?
Dell Wireless WLAN Card Wireless Network Controller has stopped working Trgovec Network & Sharing 4 30 Jul 2012
Wireless association failed beacause Windows did not receive any response from the wireless router or access point Lokerer Vista networking & sharing 8 28 Sep 2009
Vista Business wireless laptops and bluesocket wireless switch Eddie Walker Vista networking & sharing 0 05 Feb 2009
Can't detect wireless networks; HP Wireless Asst. doesn't acknowle Ed Vista networking & sharing 13 24 Jan 2009
New Intel Wireless Drivers for Vista Available, may solve some of the Wireless Connectivity Issues Edward Ray Vista networking & sharing 3 30 Sep 2006
