Vista - Scroll Wheel Desktop Icon Size Problem
Old 04-20-2007   #1 (permalink)
Shadowman
Just wondering if anyone else has experienced this. I'm running Vista
Ultimate 32-bit.
You know how you can resize the desktop icons by holding down control and
using the scroll wheel? I'm experiencing an issue where:
1. I leave the computer idle for at least 20 minutes or longer, until the
monitor turns off. During this time I may or may not have browser or other
windows open -- doesn't seem to matter. I have the power setting on High
performance, so only the monitor turns off. The computer is set to never go
into standby or hibernate.
2. I come back to the computer and move the mouse so the monitor comes back
on.
3. At this point, if I use the scroll wheel the desktop icons begin to
resize. I'm not holding down ctrl or anything, although Windows is acting as
if I'm control-scrollwheeling. If I click on something else, the wheel
functions normally again, and I can ctrl-wheel the icons back to the desired
size.
I suppose this is more of an annoyance than anything else, but I was
wondering if anyone had seen or heard of this before.
BTW, the mouse is a Logitech MX518, with the latest Vista drivers. I'm not
sure if it's something specific to the mouse or not -- I didn't see anything
mentioned at the logitech site.
Thanks,
SM
Old 01-03-2008   #2 (permalink)
Vista Home Premium 32bit
Re: Scroll Wheel Desktop Icon Size Problem
I have been experiencing something similar. Everytime I select the scroll down icon on a window or dropdown box, it causes the window to shrink or maximize depending on its current state.
I found this post:
Andre Da Costa[ActiveWin]
Posts: n/a
Re: Unable to Scroll Down in Windows
Go to Start > All Programs > Accessories and right-click
on the Command Prompt and choose "Run as administrator".
Type in: SFC /SCANNOW and press your Enter key.
This should replace/repair any corrupt files in the system.
I just ran it. Although it said it found there were some things it could not repair... it does seem to have helped. No guarantees though.
No Wheel Scroll Vista hardware & devices
Scroll wheel on mouse doesnt scroll page Vista installation & setup
Microsoft Wireless Desktop 6000 V2 under Vista - some keys not working - mouse scroll wheel 1 direction only Vista hardware & devices
Microsoft Wireless Desktop 6000 V2 under Vista - some keys not working - mouse scroll wheel 1 direction only Vista General
Annoying Mouse Problem - Scroll Wheel Button Vista General
