| | No Sound Device Installed I recently upraded to windows vista. i used the clean installation. now i have no audio devices installed to my computer. How do i get one? |
| | Re: No Sound Device Installed /Corey/ said: > I recently upraded to Windows Vista. I used the clean installation. now I > have no audio devices installed to my computer. How do I get one? If you have a separate sound card, it should have come with a device driver. Or visit the manufacturer's WEBsite. If the card is built-in to the motherboard, check with the MB manufacturer...and your documentation. |
| | Re: No Sound Device Installed You need to install a device driver (software) for your sound card (hardware on your computer) that is compatible with Vista. If you can't find a driver for your soundcard, post back with your computer make and model name/number, and perhaps someone can help you. "Corey" <Corey@discussions.microsoft.com> wrote in message news:7D67E9C4-14CC-4868-BBCE-FE0CB0E29263@microsoft.com... >I recently upraded to windows vista. i used the clean installation. now i > have no audio devices installed to my computer. How do i get one? |
| | RE: No Sound Device Installed You can try to update the driver in device manager. Click start->type devmgmt.msc in the search box and press enter. Then expand Sound category and double-click sound device below. Click Driver tab and click update driver. Choose search for the driver online automatically (I cannot remeber the exact choice :P). If there is no updated driver available, you can try to check windows update. If the updated driver is available, it will listed in the available update list. Hope this will help. Good luck ![]() "Corey" wrote: > I recently upraded to windows vista. i used the clean installation. now i > have no audio devices installed to my computer. How do i get one? |
| multiple bluetooth devices in device manager, but only one device installed????? | Drivers | |||
| New sound card installed but no sound... | Sound & Audio | |||
| USB device not installed | Vista hardware & devices | |||
| no sound output device installed.... | Vista hardware & devices | |||
| My Creative Sound Blaster X-FI Sound Card Works Now with Creative's RC1 Device Driver's! I Have Sound! | Vista General | |||
