Connecting to devices on home network
  1. #1
    spg7752 Guest
    Recently purchase a Windows Vista home premium laptop. I can't see the other
    devices on my home network (PC, Printers). I brought my laptop into my home
    network workgroup. I have file/print sharing enabled. The network map only
    shows my laptop and Internet not my desktop PC. I am able to get to the
    internet of and everything else seems ok. What am I missing???
  2. #2
    CJM Guest
    Re: Connecting to devices on home network
    Are they all members of the same workgroup?
    Can you ping them?
    Can you ping them by machine name?
  3. #3
    Steve Thackery Guest
    CJM has got it, I think. Make sure you've given the new PC the same
    workgroup name as all the others. The default is NOT the same as XP, for
    some reason.
    I experienced all sorts of weird things: the networked computers would
    intermittently appear, but only after a few minutes of fiddling about with
    Explorer. Putting the workgroup name right sorted it out instantly.
    Steve
  4. #4
    Malke Guest
    In addition to what the others have told you, here is a link to very
    good instructions about setting up networking with Vista. It is well
    worth going through them:
    File/Printer Sharing Vista -
    http://www.microsoft.com/technet/net.../vista_fp.mspx
    In addition to the instructions there, since you didn't mention what
    operating system is on the other machine see this standard note about XP
    networking. Not everything might be applicable to your situation but
    since I don't know the details of your setup, here's the whole thing:
    This is most commonly caused by a misconfigured firewall. Run the
    Network Setup Wizard on XP, making sure to enable File & Printer
    Sharing, and reboot. The only "gotcha" is that this will turn on the
    XPSP2 Windows Firewall. If you aren't running a third-party firewall or
    have an antivirus with "Internet Worm Protection" (like Norton 2005/06)
    which acts as a firewall, then you're fine. If you have third-party
    firewall software, configure it to allow the Local Area Network traffic
    as trusted. I usually do this with my firewalls with an IP range. Ex.
    would be 192.168.1.0-192.168.1.254. Obviously you would substitute your
    correct subnet. Make sure you've correctly configured your firewall on
    Vista, too (see link above).
    If one or more of the computers is XP Pro or Media Center:
    a. If you need Pro's ability to set fine-grained permissions, turn off
    Simple File Sharing (Folder Options>View tab) and create identical user
    accounts/passwords on all computers.
    (Note: I think it is easiest to network with Vista by doing this no
    matter which version of XP you have.)
    b. If you don't care about using Pro's advanced features, leave the
    Simple File Sharing enabled.
    Simple File Sharing means that Guest (network) is enabled. This means
    that anyone without a user account on the target system can use its
    resources. This is a security hole but only you can decide if it matters
    in your situation.
    Then create shares as desired. XP Home does not permit sharing of users'
    home directories (My Documents) or Program Files, but you can share
    folders inside those directories. A better choice is to simply use the
    Shared Documents folder.
    Malke
    Elephant Boy Computers
    www.elephantboycomputers.com
    "Don't Panic!"
    MS-MVP Windows - Shell/User
connecting a laptop, computer & 2 USB devices into a network DDD Vista networking & sharing 1 18 Feb 2009
Connecting to Internet via a home network James Bauer Vista networking & sharing 2 27 Jul 2008
Problem connecting to devices on my network. Nefzen Vista networking & sharing 2 07 Feb 2008
Connecting to a home network (wired) Jon Vista installation & setup 4 26 Oct 2007
VISTA - Connecting to another computer on home network Nick Vista General 6 13 Feb 2007
