Vista - Sound problems with the line in for vista (sigmatel)
Old 04-29-2007   #1 (permalink)
Scott
I recently upgraded to Windows vista. After doing so, my line in for my
sound is no longer working! my volume mixer doesnt show anything as if its
muted, its not even there.
When I right click, and select playback, it only shows speakers /
headphones, checked as if working properly, no line in is visible.
When select the recording tab, it shows my microphone as working, and
checked. underneith it shows my line in, but says "currently unavailable",
and it is not checked. (and wont let me configure). When I look further
into it, and right click, selecting properties, It says (under controller
properties) that it is working properly! It also shows that the jack
information as rear panel 3.5 mm jack (its not, its a traditional jack like a
headset or microphone utilizes. under device usage: it shows use this device
(enable).
Im sure there is some way for me to "enable" my line in jack so the sound
from my other devices comes through, but i do not know where to go.
I have a sigmatel driver. I sat through Dell customer support and
downloaded the new Driver that works for sigmatel, uninstalled the driver,
reinstalled. Also retrieved a driver directly from sigmatel for the issue,
and still nothing. This is why I presume there is just a simple setting
somewhere.
Any idea what im missing?
Old 04-29-2007   #2 (permalink)
I'm taking a guess here, so forgive me. I'm using Realtek. It sounds close to the same options, but mine as a thing where it must be set as DEFAULT. Even though it is enabled. ????
Hope it helps,
----- Update -----
Here's how to do it: Right-click on the sound icon in the system tray and select Playback Devices (or alternatively, go to Control Panel and select Sounds). Once in the Sounds window, double-click the Speakers options, then go to the Levels tab, and there you'll find the available options.
Old 04-30-2007   #3 (permalink)
Scott
Re: Sound problems with the line in for vista (sigmatel)
Unfortunatly, I have tried that avenue as well and failed. Where my mic is,
underneith it shows the microphone as "working". Under where it shows the
line in, it shows as "currently unavailable".
I have seen some new things written that express a binary change in the
regedit, but all posts that show this fix, do not have my make or model
computer. I have tried on the Dell websites as well. Just very frustrating I
am sure you can understand.
Old 04-30-2007   #4 (permalink)
Hi Scott,
Sorry to hear that. Did you increase the volume level & unmute the Playback settings. That was how I got my audio to play through the speakers from the INLINE or micIN.
Old 06-07-2007   #5 (permalink)
ed22
RE: Sound problems with the line in for vista (sigmatel)
I fixed this problem on my Dell E520 by editing the registry to enable
LineInputMonitoring.
http://direct2dell.com/one2one/archi.../30/13109.aspx
(halfway down many msgs) has the detailed procedure.
I still can't get Record What You Hear as in XP. Anybody have a fix for that?
Old 06-10-2007   #6 (permalink)
Walt an upset new DELL w/Vista owner
Forget it Scott... No Easy Fixes as yet that I know. I have done all that
you noted and downloaded a 94MB file from a sound card vendor that was
suggested in another forum. Hopefully MS or Sigmatel one will listen to the
users who are upset and do something about sound volume and record mixer
problems soon. Right now they all seem to be more interested in selling
products that are not compatable than assisting users who get roped into
buying systems that have an OEM version of Vista already installed.
> (enable).
> somewhere.
Old 06-16-2007   #7 (permalink)
josh.dahlhauser
Try re-installing vista sigmatel driver from dells support site. I had
the same problem. When you plug in a cable to the line in jack you
should get a popup window that asks how you want to use the jack. (as
line in or mic). This only works if the software is installed properly.
Josh
josh.dahlhauser
josh.dahlhauser's Profile: http://forums.techarena.in/member.php?userid=26832
View this thread: http://forums.techarena.in/showthread.php?t=738141
Old 06-24-2007   #8 (permalink)
Mike in Chicago Subs
For the Vista system, the registry key you're looking for is
"EnableInputMonitor". This is changed from 00 to 01, and a reboot is
required. However, the post/link listed below is excellent and solves the
problem. Don't know why this is disabled by default and it takes a rocket
scientist to correct, but then we'll never know!
Old 07-30-2007   #9 (permalink)
sirishti
> (enable).
> somewhere.
Old 07-30-2007   #10 (permalink)
Cal Bear '66
Right click on the Speaker icon in the Notification Area of the Taskbar, select
Recording Devices, in an empty area of the Recording Devices window, right click
and make sure that both "Show Disconnected Devices" and "Show Disabled Devices"
are checked.
I Bleed Blue and Gold
GO BEARS!
"sirishti" <sirishti@discussions.microsoft.com> wrote in message
newsC43767F-ECD1-4BB1-B46B-0E11BB4A9E57@microsoft.com...
>> (enable).
>> somewhere.
SigmaTel Audio(no sound) after Vista upgrade Vista General
Problem with sigmatel sound card on Vista x64 Ultimate (OEM version) on Dell D820 Vista hardware & devices
Sound Problems - Sigmatel Vista music pictures video
No sound on my PC with C-Major Audio Sigmatel Vista hardware & devices
No sound with my C-Major Sigmatel Device ! Vista hardware & devices
